i am trying to mount the emmc of an imx8qm device with a new yocto build. However with the new build (and u-boot) it is not possible on my windows nor my linux machine to mount the emmc.
I get the following error
Apalis iMX8 # ums 0 mmc 0
UMS: LUN 0, dev 0, hwpart 0, sector 0x0, count 0x1da4000
We are in is_imx8
Getting phy ctrl
We are in is_imx8
Getting phy ctrl
No USB device found
Couldn't init USB controller.
The whole boot sequence is:
U-Boot 2020.04-5.1.0-devel+git.0a26a04408ca (Dec 28 2020 - 14:02:46 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / BT IT V1.1B, Serial# 06738462
BuildInfo:
- SCFW 732e719a, SECO-FW 376e3c15, IMX-MKIMAGE 6745ccdc, ATF
- U-Boot 2020.04-5.1.0-devel+git.0a26a04408ca
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
We are in is_imx8
Getting phy ctrl
We are in is_imx8
Getting phy ctrl
No USB device found
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
Fastboot: Normal
Normal Boot
Apalis iMX8 #
Apalis iMX8 #
Apalis iMX8 # usb start
starting USB...
Bus usb@5b0d0000: usb dr_mode not found
USB EHCI 1.00
Bus usbh3: XHCI-imx8 init hccr 0x000000005b130000 and hcor 0x000000005b130080 hc_length 128
Register 2000820 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@5b0d0000 for devices... 1 USB Device(s) found
scanning bus usbh3 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
We are in is_imx8
Getting phy ctrl
We are in is_imx8
Getting phy ctrl
No USB device found
Apalis iMX8 #
