Can not make " repo sync"
I am trying to follow this article
to build the tdx-reference-multimedia-image
unfotunatly when i reached 9/13 percentage in “repo sync” step
I got an error said:
fatal: unable to access ‘Making sure you're not a bot!’: server certificate verification failed. CAfile: none CRLfile: none
please let me know if this is a repo problem or it is from my side.
because really I’ve tried to open the link and there were no repositories there
please advise.
Rama
Dear @rama.aloufee,
Can you please share more information about your issue?
  • What is the Operating System of your machine?
  • Have you tried to do this on another machine?
  • Have you installed repo through this command: curl https://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo or through sudo apt install
  • Do you have python or python3 installed on your machine?
I just made a test here and it seems to work on my side without any problems. I’m using Ubuntu 22.04 LTS and the repo installed with curl.
it worked when i installed python3-distutils, also update ca-certificates
sudo apt-get install python3-distutils
sudo apt-get install apt-transport-https ca-certificates -y
sudo update-ca-certificates
thanks
Glad it’s working now :smiley:
I had this happen, and installing python-is-python3 made it work for some reason.
