Hi All.
I flashed https://developer1.toradex.com/files/toradex-dev/uploads/media/Colibri/Linux/Images/Colibri-iMX6_LXDE-Image_2.7-20180104.tar.bz2 on the Colibri-board successfully, and started receiving U-Boot messages fine via the USB.
Now, upon doing dmesg | grep can, following output is seen :
root@colibri-imx6:~# dmesg | grep can
[ 0.140448] i2c i2c-1: can't use DMA
[ 0.141132] i2c i2c-2: can't use DMA
[ 1.255588] vcan: Virtual CAN interface driver
[ 2.007130] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 2.172600] can: controller area network core (rev 20120528 abi 9)
[ 2.187157] can: raw protocol (rev 20120528)
[ 2.193295] can: broadcast manager protocol (rev 20120528 t)
[ 2.200834] can: netlink gateway (rev 20130117) max_hops=1
However, upon doing lsmod | grep can, absolutely nothing is seen.
Also, I searched in the entire filesystem, and could not find any of can.ko or vcan.ko
I am failing to understand what’s happening.
Will be grateful to hear back from you experts !!
Thanks and Regards,
Ajay
