CAN controller makes CRC delimiter too short
Hi all,
I am using the Verdin IMX8MM v1.1a in our own carrier board. We already use the CAN bus on the Verdin to talk to some pressure sensors and that appears to work fine. However, I have found a problem when trying to talk to a new device we would like to use. This only transmits and sends messages every 250 ms at 250 kbps.
After a fair amount of investigation I have got to:
  • The device I am talking to works ok when connected to a Korlan USB2CAN and Wireshark
  • When connected to my carrier with the CAN transceiver powered and enabled it works ok repeatedly sending a packet without getting and ACK
  • When I bring up the SocketCAN interface with ip link set can1 up type can bitrate 250000 the device sends a number of packets and these are received by my application but it gives up due to to many errors after about 30 attempts
I think the reason is that the CAN controller on the Verdin board is not respecting the CRC delimiter length so the communicating device does not realise it has had an ACK so repeats the packet and then we start getting errors and then it gives up.
This is a good plot showing the ACK and a full width CRC delimiter:
This is a bad plot showing the ACK too early:
Happy to explain more if this is not clear. I am open to any suggestions, perhaps there is a way to configure this parameter? Maybe in device tree?
Perhaps @Edward or @jaski.tx have some thoughts.
Thanks very much
Ed
Hi @edwaugh ,
Before diving so deep, did you check bitrates are OK? My favorite way to check it - jest let single node send something. Nothing else should be connected to the bus, just sending node and scope. Find minimum pulse width T. 1/T should match your bitrate. Any visible deviance from target bitrate is bad sign. You should check it for both, your Verdin and sensor.
Edward
Thanks Edward, I did check this and thought it was ok. Also both the verdin and usb2can should be set the same. I will confirm by measurement.
You didn’t say you checked bitrate with scope. ip link bitrate is of course fine, but sometimes you need to check it physically. It could be driver bug, it could be something wrong with clock.
You may need as well to check sampling point position specified in your sensor datasheet and and specify detail timings using ip link set command, tq, prop-seg, phase-seg1, phase-seg2, sjw.
MCP2517FD, difficulties with baud rate settings (force.com)
  • Different SPs lead to different lengths of the BRS bits and CRC delimiter bits in the different nodes.
^^ sounds having something to do with you first message.
Edward
Hi @Edward,
Thanks for the advice. I took a look at the timing and as far as I can tell they look ok, <1% error from the target bit rate;
Device Measured bit period (us) Effective Bus rate Error %
Verdin board (v3 CAN1) 4.005 249687 0.125%
Kimax2 4.026 248385 0.646%
Korlan USB2CAN 4.0075 249532 0.19%
Kimax2:
![kimax2_timing_8-052us 690x339](upload://8AO2HjSa1BGDUWlPPqlVjb1Xq5o.png)
Korlan USB2CAN:
![KorlanUSB2CAN_timing_8-015us 690x314](upload://6UzFNJCzWhokGmxatAzolJ1jsHS.png)
Verdin:
![verdin_timing_can1_8-010us 690x317](upload://276CA0cAqNi9YSPabGPpUvmzGrE.png)
  • I also tried adjusting the sample point to 75% and 90% to see if things improved but no luck.
What I can see right now is;
  • With the 3 devices above on the same bus the Kimax2 can transmit happily to WireShark on the Korlan USB2CAN while Verdin CAN1 is down.
  • If I bring up the interface at the command line using
sudo ip link set can1 up type can bitrate 250000
candump can1
  • I do not get any data from candump and the bus continues running
  • However if I bring up the bus from my Python application using the command below and nothing else it stops working:
subprocess.run(['ip', 'link', 'set', interface, 'up', 'type', 'can', 'bitrate', '250000'], stdout=subprocess.PIPE, text=True)
Suggestions very welcome, I am a little bit stumped as to what to try next. Maybe I will look at the USB2CAN talking to the Verdin.
Ed
Hi @edwaugh ,
Well, with such timing differences at least some messages should be received and acked. Sampling point usually affects long buses, it shouldn’t matter a lot at short distances.
Perhaps it has something to do with CAN FD capability of MCP2517FD? Could you try adding fd off at the end of your ip link set command? To see whole list of other ip link settings use ip link set can0 type can help.
Regarding issuing ip link set from python vs no python. Are you sure interface name is the same in both cases?
Edward
Hi @Edward
I haven’t made much progress the rest of today, thanks for your suggestions, I tried all the options I could find under the help section and no improvement. I am now in the position that:
  • Kimax2 transmits to the USB2CAN device correctly
  • Verdin transmits and receives to the USB2CAN device correctly
  • Kimax2 and Verdin together cause the CRC delimiter error and stop working after a short while
    These are all connected in all states just with different devices enabled on the bus. Electrical signals look good, low noise and ringing etc. Cable lengths are a few metres.
    Can you think of anything I could measure about the working signals to identify the problem?
    Or anything I could ask the supplier of the Kimax2 that might help understand the problem?
Thanks very much
Ed
Hi @edwaugh ,
MCP2518FD I tried seems working well with zoo of MCUs from various vendors. I doubt MCP2517FD is much worse than that. But something is causing this problem for you. Is it transceiver, circuit issue, something wrong in MCP2517FD, something wrong with Kimax2? I don’t know. Do you know what MCU is used in Kimax2?
Edward
Hello Edward,
thank you for you input.
Matthias
I got a response from the manufacturer:
  • The CAN controller in the Kimax unit is a MAX3053ESA+ chip.
  • Sample point is 81,3.
  • Detailed timing parameters are:
  • BRP = 5
  • Tseg1 = 12
  • Tseg2 = 3
  • SJW = 1
Update I realised the part above is the transceiver and not the controller. I have asked for the controller as well.
More information from the supplier:
We are using the built in CAN controller of our PSoC5 microcontroller (Cypress semiconductors). The CAN controller implements the CAN2.0A and CAN2.0B specifications as defined in the Bosch specification and conforms to the ISO-11898-1 standard at a bit rate of 250 kbps.
Hi all,
I think I have resolved the issue, using the information from the supplier I set the sample point to exactly 0.813 and it worked. I had previously tried values around this area like 0.8 and 0.85 so that makes me a bit concerned that it needs to be so exact and, as far as I can tell, non-standard.
Thanks for all the suggestions.
Ed
Hi @edwaugh ,
Thanks for feedback. Is it clear for you which node to blame or are you going to conduct more tests to determine which end is broken?
I haven’t met such situation yet, no idea how so strict SP could matter. Dominant bits shorter/wider than recessive? Too long edges in waveform? I don’t know
Edward
