Can-bus imx6 dotnet c# no sample code WINCE
We are trying to get the new TdxAllLibraryDll.dll working in C#. We have opened the port and we have a message appearing on our CAN monitor software, but we are unsure how to use the CAN-Write and CAN_Read functions.
We are using the can.tCanMsg structure to build our CAN message. Our sample code is as follows:
    public static void Write(int CANPort, Char[] message, UInt32 messageID)
        can.tCanMsg canMessage = new can.tCanMsg();
        canMessage.data = message;
        canMessage.dataLen = 8;
        canMessage.id = messageID;
        if (CANPort == 1 && canPort1 != IntPtr.Zero)
            GCHandle handle1 = GCHandle.Alloc(canMessage);
            IntPtr ptrMessage = (IntPtr) handle1;
            uint ret = can.Can_Write(canPort1, ptrMessage, 1);
            handle1.Free();
The version of the DLL is 2.0.0.3858.
Please help.
Got the Write working with:
        can.tCanMsg canMsg = new can.tCanMsg();
        canMsg.data = message;
        canMsg.dataLen = 8;
        canMsg.id = messageID;
        IntPtr ptrBuf = Marshal.AllocHGlobal(Marshal.SizeOf(canMsg));
        Marshal.StructureToPtr(canMsg, ptrBuf, false);
            uint ret = can.Can_Write(canPort1, ptrBuf, 1);
        if (CANPort == 2 && canPort2 != IntPtr.Zero)
            uint ret = can.Can_Write(canPort2, ptrBuf, 1);
Dear @nickwalt
I’m glad you found the solution yourself. Don’t hesitate to get back in case you experience further issues.
