We are using Yocto release in our Toradex “Apalis iMX8QP” board and we have a can hub that connects up to 6 boards that contains MCU as PIC32MX and PIC18F25K83.
Toradex communicate the other boards via canbus.
There is also a can hub board in the system that all boards can connect.
When we connect the MCU boards to the canhub board the communication is stable and all data flow is correct without any error frame.
We build the Yocto for Toradex that can send and receive canbus data. We tried this process by using Kvaser usb-can converter. There is no error frame occured when we connect the can-high can-low to Kvaser tool.
When we connect the MCU boards to Kvaser there is not any error frame also.
They are working correctly separately.
But when we connect the Toradex board and MCU boards through canhub board there are lots of Error Frames occured.
The canbus bitrate is 125kbps.
We suspect the bit quanta timings.
We use Flexcan in Toradex Board.
What can be the main reason of error frames?
