Hi there!
Im using the ixora carrier boards’ CAN pins, but our devices only recognise that a CAN signal has been sent out if we connect an external 120ohm resistance to the cable we used to connect the board and the can device.
Im wondering if there is an internal option for this, and the board has a 120ohm CAN closing resistance, that can be switched on. If so, i would like your help on how i could turn this feature on.
Thanks in advance!
