Can anyone suggest me a point of contact in toradex to enquire and get solution regarding iMX95 Verdin development kit
I am currently working on iMX95 Verdin Development kit and have queries regarding the ISP flow, its working. Can anyone suggest me point of contacts and mail loops , currently I am unable to receive any replies from them
I can help you with your iMX95 Verdin Development kit ISP flow questions. To provide the most accurate guidance, could you let me know which OS and version you are using? You can use the tdx-info command to get detailed information about your setup - find more details here.
Support Channels
For technical support with your Verdin iMX95, you have several options available(1):
Verdin iMX95 Resources
For your ISP flow work, these resources may be helpful(1):
The iMX95 includes an integrated ISP that eliminates the need for cameras with integrated ISPs, allowing support for larger sensors with the ISP functionality built into the device itself.
Would you like a general answer based on my knowledge instead if the specific ISP flow information you need isn’t covered in these resources?
