Hello there,
i’m working on an imx6q and i’m trying to write in c ++ my python application that acquires video from an analog camera.
The problem is that he doesn’t seem to like the pipeline. I summarize the situation in detail:
Apalis iMX6 Quad 2GB IT V1.1C
ACA ADV7280
Ixora V1.2A
Customized image Yocto based on Alapis-iMX6_LXDE-Image_2.8b7
I only added python and opencv 3.3 as described here and here
oe-core/build/conf/local.conf
IMAGE_INSTALL_append = "python opencv"
oe-core/layers/meta-openembedded/meta-oe/recipes-support/opencv/opencv_3.3.bb
CXXFLAGS += " -Wa,-mimplicit-it=thumb"
Then i populate skd and configure it to cross compile with opencv libs ( always following this)
And this is the result:
ACA ADV7280 drivers are correclty loaded:
root@apalis-imx6:~# dmesg | grep adv
[ 5.601368] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 5.601399] adv7280 3-0021: no sensor pwdn pin available
[ 5.665895] mxc_v4l2_master_attach: ipu0:/csi0 parallel attached adv7280:mxc_v4l2_cap0
Analog camera is detected:
root@apalis-imx6:~# v4l2-ctl --list-devices
/dev/video0
/dev/video16
/dev/video17
root@apalis-imx6:~# v4l2-ctl -V -d /dev/video0
Format Video Capture:
Width/Height : 720/576
Pixel Format : 'UYVY'
Field : Any
Bytes per Line : 1440
Size Image : 829440
Colorspace : Default
Transfer Function : Default
YCbCr/HSV Encoding: Default
Quantization : Default
GStreamer pipeline works (as in documentation):
gst-launch-1.0 imxv4l2videosrc device=/dev/video0 ! imxipuvideosink use-vsync=true
Python3 application works:
import numpy as np
import cv2
cap = cv2.VideoCapture("imxv4l2videosrc device=\"/dev/video0\" ! videoconvert ! appsink")
cv2.namedWindow("frame", cv2.WINDOW_NORMAL)
cv2.setWindowProperty("frame", cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN)
while 1:
if cap.isOpened():
ret, frame = cap.read()
cv2.imshow('frame',frame)
if cv2.waitKey(10) & 0xFF == ord('q'):
break
cap.release()
cv2.destroyAllWindows()
C++ Application doesn’t work:
#include <opencv2/opencv.hpp>
using namespace cv;
int main(int argc, char *argv[]){
Mat image;
namedWindow("frame" , CV_WINDOW_NORMAL);
setWindowProperty("frame" , WND_PROP_FULLSCREEN , WINDOW_FULLSCREEN);
VideoCapture cap;
cap.open("imxv4l2videosrc device=\"/dev/video0\" ! vidoeconvert ! appsink" );
while (1) {
if (cap.isOpened()) {
cap >> image;
cv::imshow("frame" , image);
:waitKey();
destroyAllWindows();
return 0;
(frame:1604): GStreamer-CRITICAL **: gst_caps_intersect_full: assertion 'GST_IS_CAPS (caps1)' failed
(frame:1604): GStreamer-CRITICAL **: gst_mini_object_unref: assertion 'mini_object != NULL' failed
OpenCV Error: Unspecified error (GStreamer: unable to start pipeline
) in cvCaptureFromCAM_GStreamer, file /usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/videoio/src/cap_gstreamer.cpp, line 881
VIDEOIO(cvCreateCapture_GStreamer (CV_CAP_GSTREAMER_FILE, filename)): raised OpenCV exception:
/usr/src/debug/opencv/3.3+gitAUTOINC+87c27a074d_2a9d1b22ed_a62e20676a_34e4206aef_fccf7cd6a4-r0/git/modules/videoio/src/cap_gstreamer.cpp:881: error: (-2) GStreamer: unable to start pipeline
in function cvCaptureFromCAM_GStreamer
I also say that other features of opencv seem to work. I don’t know if in c ++ I have to indicate the pipeline in another format? Or do I have to enable something or recompile the image with other flags (I don’t think since the documentation says opencv from image 2.7 already comes with gstreamer support)?
Thank you very much
Regards
