Calculate serial number from mac address
The docs describe how the mac address is linked to the SOM serial number here MAC Address | Toradex Developer Center (if the mac address has not be forced to another value). Could you provide some python script in addition to the MAC Address | Toradex Developer Center for linux users (or other users which do not have ms excel)?
You can use this formula:
serial = int('<Serial#>')
print("00:14:2D:" + format((serial >> 16) & 0xFF, '02X') + ':' + format((serial >> 8) & 0xFF, '02X') + ':' + format(serial& 0xFF, '02X'))
Great, thanks a lot!
…but I need the other way around: mac → serno
Here:
mac = '<MAC>'
serial = (int(mac[9:11], 16) << 16) + (int(mac[12:14], 16) << 8) + int(mac[15:17], 16)
format(serial, '08d')
Thanks a lot!
BTW: The serial number also gets passed from U-Boot via device tree:
root@apalis-tk1:~# cat /proc/device-tree/serial-number; echo
02858976
The prefix 00:14:2D is independent of the TK1 SOM HW version (V1.1A vs. V1.2A), right?
Yes, that’s the Toradex OUI (Organizationally Unique Identifier).
Great, thx.
you are welcome.
I understand this is an old post, but I’m running into an issue trying to mac-to-serial the second mac address. The issue I’m seeing is that the second mac address generates a valid serial number, but it’s not the serial number of the device. I understand that if I knew I was looking at the second mac address then I could subtract 0x100000, but when I see the mac address from the network (nmap scan) I cannot tell whether I’m on the first or second ethernet.
Is there any extra info I can use to determine whether I’m looking at the first or second mac address?
Hi @lucashutyler
Have you checked this page?
Also, on the device, there is this script that is called by the set-hostname.service
/usr/bin/sethostname
If you have further questions,
could you open a new thread so we can keep a better track of it?
