How can I install the Toradex .NET compact Framework 3.5 cab-file as a part of an unattended (silent) production script (autorun batch job from SD/USB). Default install dir is ok. I just want to automate the installation of this cab file.
Thanks.
Dear @EmbedX,
Could you try this command :
wceload /noui "\Flashdisk\Toradex_NETCFV35_CE700_FlashDisk.cab"
and let me know if it not working for you.
Hi there.
Yes, it is working. Also discovered all the cmd line options for Your update.exe tool. Nice job.
Thanks.
Hi there.
Thanks.
