CAAM - best way to make writable aread for key blob
Thanks for your response.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Hello Paul,
Thank you for your follow-up and glad the key storage issue is resolved!
The error:
device-mapper: reload ioctl on encdata (254:0) failed: Device or resource busy
indicates that the encdata dm-crypt device is already in use, mounted, or there is a timing conflict during service startup.
Troubleshooting Steps:
  1. Check if encdata is already active:
    dmsetup ls
    lsblk
    Look for a device named encdata in the output. If it’s there, list the mount points:
    lsblk -f
  2. Unmount and Remove Device if Needed:
    If /run/encdata or a similar mount point is in use, unmount it:
    umount /run/encdata
    Then, remove the device mapper target:
    dmsetup remove encdata
  3. Restart the Encryption Service (after cleanup):
    systemctl restart tdx-enc-handler.service
  4. Check for Service Conflicts/Timing:
    It’s possible that automatic mounting or another service is trying to use the device at the same time as tdx-enc-handler. Double-check that:
    • The partition for encryption isn’t being auto-mounted by systemd or /etc/fstab.
    • No other service is accessing the device during boot.
    There have been recent improvements to address timing issues; ensure you’re using the latest Torizon image and meta-toradex-security layer (see discussion: Device or resource busy error: community thread).
  5. Persistent Issue:
    If the error persists after a reboot and following the steps above, please provide:
    • Output of lsblk and dmsetup ls
    • The content of your relevant encryption configuration (e.g., TDX_ENC_* variables)
    • Journal output: journalctl -u tdx-enc-handler.service
Helpful links:
Let me know the outcome or share more details if the issue continues!
