Hello Paul,
This is a common issue when using CAAM keys with a read-only root filesystem. By default, the encryption key blob is stored in /var/local/private/.keys/, which is not writable on a read-only rootfs.
There are a couple of ways to address this. Here are the options:
1. Partition-Based Key Storage (Recommended for Read-only Rootfs)
Instead of storing the key in the root filesystem, you can configure the system to store the encryption key blob in a reserved block of your data partition (outside the encrypted volume). To do this, set the following variables in your configuration:
TDX_ENC_KEY_LOCATION="partition" tells the system to use partition-based key storage (not the root filesystem).
TDX_ENC_STORAGE_RESERVE="1" reserves a block for the key blob.
Ensure your TDX_ENC_STORAGE_LOCATION points to the correct partition intended for data-at-rest encryption.
This approach is specifically designed for read-only rootfs systems.
2. Change the Key Directory to a Writable Partition
If you prefer to continue storing the key blob in the filesystem, redirect the storage location to a writable part of your filesystem, such as /data/.keys:
TDX_ENC_KEY_DIR="/data/.keys"
You would then ensure /data is a writable partition and exists before running the encryption setup. This avoids modifying the root filesystem while keeping the key storage flexible.
Overlay or Symlink
While adding an overlay, bind-mount, or symlink from /var/local/private to /data/.keys could work as a workaround, it is typically better to use the configuration options above. This keeps your system maintainable and leverages the built-in flexibility.
Please see the Toradex documentation for more details and examples:
Let me know if you need help with modifying your configuration files or have other questions.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Hello Paul,
Thank you for your follow-up and glad the key storage issue is resolved!
The error:
device-mapper: reload ioctl on encdata (254:0) failed: Device or resource busy
indicates that the encdata dm-crypt device is already in use, mounted, or there is a timing conflict during service startup.
Troubleshooting Steps:
Check if encdata is already active:
dmsetup ls
lsblk
Look for a device named encdata in the output. If it’s there, list the mount points:
lsblk -f
Unmount and Remove Device if Needed:
If /run/encdata or a similar mount point is in use, unmount it:
umount /run/encdata
Then, remove the device mapper target:
dmsetup remove encdata
Restart the Encryption Service (after cleanup):
systemctl restart tdx-enc-handler.service
Check for Service Conflicts/Timing:
It’s possible that automatic mounting or another service is trying to use the device at the same time as tdx-enc-handler. Double-check that:
The partition for encryption isn’t being auto-mounted by systemd or /etc/fstab.
No other service is accessing the device during boot.
There have been recent improvements to address timing issues; ensure you’re using the latest Torizon image and meta-toradex-security layer (see discussion: Device or resource busy error: community thread).
Persistent Issue:
If the error persists after a reboot and following the steps above, please provide:
Output of lsblk and dmsetup ls
The content of your relevant encryption configuration (e.g., TDX_ENC_* variables)
@ToradexAI
the device to encrypt is /dev/mmcblk0p3 which is already mounted on /data.
Is it a problem, that the .keys directory is on the same partition ?
Hello Paul,
Yes, this is exactly the core issue. You cannot encrypt a partition that is already mounted and in use—especially when the encryption key is stored on the same partition. This creates a circular dependency and prevents proper setup of dm-crypt.
Here’s why:
/dev/mmcblk0p3 is mounted on /data
The encryption key (.keys) is stored on /data/.keys (same partition)
You’re trying to set up dm-crypt on /dev/mmcblk0p3, but you can’t access the key once the partition is locked, and you can’t set up encryption while it’s mounted
To solve this, you have two reliable options:
1. Use Partition-Based Key Storage (Recommended)
This method stores the key blob in a reserved block outside the encrypted filesystem area, avoiding the circular dependency:
2. Store Keys on a Different Writable Partition
If you still want to use filesystem-based storage, set the key directory to a location NOT on /dev/mmcblk0p3. For example:
TDX_ENC_KEY_DIR="/var/persistent/.keys" # or another partition, not /data
Extra:
If you must perform encryption setup, ensure /dev/mmcblk0p3 is not mounted. You can unmount it and restart the encryption handler:
Hello Paul,
Thank you for your feedback! You are correct—the page is in Chinese, and machine translations may not be clear. Let me summarize the key technical points in English for clarity:
How to Solve Key Storage for Encrypted Partitions (/dev/mmcblk0p3 Mounted as /data):
When you want to encrypt a partition that is already used for data (like /dev/mmcblk0p3 on /data), do not store your encryption key (.keys directory) on the same partition. This leads to a circular dependency and the “Device or resource busy” error.
The recommended solution is to use Partition-Based Key Storage.
Here’s how you configure it:
In your Yocto/local.conf or relevant config, set these variables:
The encrypted partition will be available through /dev/mapper/encdata and typically mounted at /run/encdata by default.
This approach avoids storing the key blob on a filesystem that will be locked/encrypted, fully resolving the circular dependency and device busy errors.
Relevant documentation (in English) is also available:
Hi Bruno,
it might just be that my expectations were wrong.
Because i made the rootfs read-only and needed a writable partition as well i used INHERIT += “tdx-tezi-data-partition” to get the /data partition where i also created the overlay-fs for writing to /etc.
I then expected that when adding the INHERIT += “tdx-encrypted” that i would end up with a /data partition that was encrypted.
But as the default is to store keys in /var/local/private that didn’t work with the read-only rootfs.
So as rootfs (mmcblk0p2) is read-only and /data (mmcblk0p3) is being encrypted, the keys cant be on a filesystem.
did not work - i end up with the kernel in emergency mode
(If /data is on mmcblk0p3 and i manually add mmcblk0p4 in image.json and then chose p4 for encryption i of course get both /data (uncrypted) and /run/encdata partitions.)
Hello Paul,
This is exactly the issue you’re encountering. When using tdx-tezi-data-partition with tdx-encrypted, the system is trying to mount the same partition both as a regular filesystem and as an encrypted device.
The Solution: Configure Automount Settings
The key is to prevent the automatic mounting of the data partition when it’s going to be encrypted. The tdx-tezi-data-partition class has built-in logic for this scenario (1)(2).
TDX_TEZI_DATA_PARTITION_AUTOMOUNT = "-1" - This prevents the partition from being added to /etc/fstab entirely, so systemd won’t try to mount it during boot (1)(2)
TDX_ENC_KEY_LOCATION = "partition" - Stores the encryption key in a reserved block outside the encrypted filesystem (1)(2)
TDX_ENC_STORAGE_RESERVE = "1" - Reserves one block (512 bytes) for the key blob (1)(2)
Why This Happens
By default, when tdx-encrypted is used with tdx-tezi-data-partition, the system automatically sets TDX_TEZI_DATA_PARTITION_AUTOMOUNT = "-1" to avoid exactly this conflict (1)(2). However, if you’ve explicitly set it to a different value, you need to ensure it’s set to -1 to prevent the boot-time mounting conflict.
After Configuration
Once properly configured:
The raw partition /dev/mmcblk0p3 won’t be auto-mounted
The tdx-enc-handler service will set up dm-crypt on /dev/mmcblk0p3
The encrypted filesystem will be available at /dev/mapper/encdata
It will be mounted at /run/encdata (or your configured TDX_ENC_STORAGE_MOUNTPOINT)
This should resolve both the emergency mode issue and prevent the dual mounting attempts.
@ToradexAI
no, i now made a separate mmcblk0p4 partition that gets encrypted which is not the TDX_TEZI_DATA_PARTITION. Is there a variable to set mount options for that ?
Let me check the available documentation for configuration variables related to mount options for encrypted partitions.
Based on the available documentation, there are specific variables for configuring mount options for encrypted partitions:
Mount Options for Encrypted Partitions
For your encrypted partition (/dev/mmcblk0p4), you can use the following variables:
TDX_ENC_STORAGE_MOUNT_ARGS - Set extra arguments passed to mount when mounting the encrypted filesystem
TDX_ENC_STORAGE_MKFS_ARGS - Set extra arguments passed to mkfs.ext4 when creating the filesystem on the encrypted storage
Your Configuration
Your current setup looks correct for having separate partitions:
/dev/mmcblk0p3 - Regular data partition (from tdx-tezi-data-partition)
/dev/mmcblk0p4 - Encrypted partition
The TEZI_DATA_FSOPTS = "-O verity -E nodiscard" you’re using applies to the regular data partition created by tdx-tezi-data-partition, not the encrypted one.
Example Configuration
INHERIT += "tdx-tezi-data-partition tdx-encrypted"
TDX_ENC_STORAGE_LOCATION = "/dev/mmcblk0p4"
TDX_ENC_KEY_BACKEND = "caam"
# Mount options for the encrypted partition
TDX_ENC_STORAGE_MOUNT_ARGS = "noatime,nodiscard"
TDX_ENC_STORAGE_MKFS_ARGS = "-O verity -E nodiscard"
TDX_TEZI_DATA_PARTITION_AUTOMOUNT = "1"
EXTRA_IMAGE_FEATURES += "read-only-rootfs"
# This applies to the regular data partition, not encrypted
This way you can set specific mount and filesystem creation options for your encrypted partition separately from the regular data partition.
@ToradexAI
that results in the encrypted partition not getting mounted on /run/encdata - i only wanted to avoid the attempt to mount mmcblk0p4 directly and the system trying to determine the filesystem type.
Thanks for your response.
Please remember to tick the "Solution" checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Hello Paul,
I understand now - you want to prevent the system from trying to mount /dev/mmcblk0p4 directly as a regular filesystem (which causes filesystem detection issues), but you still want the encrypted partition to be properly mounted at /run/encdata.
The Issue
When you create a separate partition (/dev/mmcblk0p4) for encryption, the system may try to auto-mount it during boot before the encryption handler can set up dm-crypt. This causes conflicts and filesystem type detection errors.
Solution: Prevent Auto-mounting of the Raw Partition
To prevent the system from trying to mount /dev/mmcblk0p4 directly while still allowing the encrypted version to mount at /run/encdata, you need to ensure that:
The raw partition is not in /etc/fstab - Since you're creating mmcblk0p4 manually (not via tdx-tezi-data-partition), make sure it's not being added to fstab by any other mechanism.
Don’t add TDX_ENC_STORAGE_MOUNT_ARGS unless you need specific mount options
Ensure proper partition creation in image.json - When you manually add mmcblk0p4 to your image.json, make sure it doesn't have an fstab entry or auto-mount configuration.
Verification
After boot, you should see:
/dev/mmcblk0p3 mounted as /data (regular data partition)
/dev/mmcblk0p4 NOT directly mounted
/dev/mapper/encdata mounted at /run/encdata (encrypted partition)
Check with:
lsblk
mount | grep encdata
systemctl status tdx-enc-handler.service
The key is ensuring that /dev/mmcblk0p4 is never referenced in /etc/fstab or any systemd mount units, so only the encryption handler accesses it.
