C#-TCP-Clients keeps waiting on Receive-Method forever
Overview
We have a TCP-communication between a PC and a Toradex Evalboard with IMX6. Network outage longer than 10s cause the client to get stuck and waiting forever for the data from the server. We expect that the client throws a SocketException if he can no longer communicate with the server. We don’t want the client to get stuck on the NetworkStream.Receive(…)-method. This issue only occurs with Colibri IMX6, it does not occur with Colibri PXA.
Detailed Description
On the Toradex Evaluation Board there is a TCP-server listening on port 64001. On the PC there is a TCP-client which connects to this port 64001.
Step-by-step description if the network cable is NOT unplugged
Client: sends a “POST /” to the server and is waiting to receive text from server
Server sends:
HTTP/1.1 200 OK
Content-Type: application/json
Content-Length: 25
Server is waiting 10 seconds and then sends:
this is data !!! and even more data
Client receives data and writes it to the console.
Step-by-step description if the network cable is UNPLUGGED
But if the network cable is unplugged for more than 10 s and then plugged in again the client is waiting forever to receive data from the server. Here a step-by-step description of this:
Client: sends a “POST /” to the server and waiting to receive text from server
Server sends:
HTTP/1.1 200 OK
Content-Length: 25
User unplugs network cable from PC
User plugs in network cable again into the PC
Client writes this to the console and then waits forever:
HTTP/1.1 200 OK
Content-Length: 25
Description of the environment
TCP-server is running on:
Toradex Colibri Evaluation Board 3.2
Colibri IMX 6 DL512MB IT
WinCE8.0 BSP 1.6
Compact Framework 3.9
Error occurs with original Toradex WinCompact2013 image “103192-imx6-wince-image.zip”, version 1.7
This issue does not occur with Colibri PXA 310 and WinCE6.0.
TCP Server
TCP-Server is implemented in C# and Compact Framework 3.8. The file “ConsoleApplication1.zip” contains the Visual Studio Solution 2015 for the server.
TCP Client
TCP-Client is running on a PC with Windows 10 Enterprise Version 20H2 with .NET Framework 4.8. The file “ClientTestApplication.zip” is the Visual Studio Solution 2019-solution for the client.
WireShark
To investigate this issue we used a network switch with port 1 mirrored to port 5.
Port 1: Toradex Eval Board/Colibri IMX with IP10.41.46.10/24
Port 2: C#-client running on PC with IP 10.41.46.11/24
Port 5: PC with Wireshark with IP 10.41.46.219/24
In Wireshark we can see 4 TCP retransmissions. Last retransmission is 6 seconds after sending the TCP-packet for the first time (Packet-IDs 1600, 1603, 1608 and 1619). We can also see ARP-requests “Who has 10.41.46.11” (Packet-IDs 1625, 1630 etc.) and an ARP-reply “ARP announcement for 10.41.46.11” (Packet-ID 1732) after the cable is plugged in again. But the is no TCP-retransmission anymore.
The wireshark-file can be downloaded here:
TCP_Communication_10-41-46-11_10-41-46-10-network-interruption__TcpMaxDataRetransmission_not_set_client_is_blocking2.pcapng
Please use this filter in WireShark:
(ip.addr != 10.41.46.219 && (tcp)) || (arp.src.proto_ipv4 == 10.41.46.10) || (arp.src.hw_mac == c8:5b:76:bc:21:c2)
Found Solution
After investigating for some time we found a Windows-registry key named
“TcpMaxDataRetransmissions” under “HKEY_LOCAL_MACHINE\Comm\Tcpip\Parms”, which allows to adjust the number of TCP-retransmissions in case of network outage.
Here is the documentation: IPv4 and IPv6 Configurable Registry Settings (Compact 2013) | Microsoft Learn
In Wireshark we can see again the 4 TCP-retransmits (Packet-IDs 119, 120, 129 and 172)
followed by ARP-requests “Who has 10.41.46.11” (Packet-IDs 195, 216, 219 etc) and an ARP-reply “ARP announcement for 10.41.46.11” (Packet-ID 459) after the cable is plugged in. This time however there is a 5th TCP-retransmission (Packet-ID 712). The client can now read the text from the server is no longer stuck in NetworkStream.Read(…)-method.
TCP_Communication_10-41-46-11_10-41-46-10-network-interruption__TcpMaxDataRetransmission=220.pcapng
Hi @ezeh ,
Welcome to the Toradex community.
Thanks for leaving this here other users will surely appreciate it.
If Toradex can help you anywhere let us know.
Kevin
I am the original poster of the question and I was investigating this issue further and found the suggested solution above is not complete.
Setting the WinRegistry-Key " TcpMaxDataRetransmissions" only work if all IP-adresses ared fixed and DHCP is turned off.
But…
Using DHCP-server causes “Toradex Colibri Evaluation”-board to request a new IP-address whener the Ethernet-Cable (RJ-45) is plugged out and plugged in. The requesting of new IP-address seems to make the network card unavailable for some time and causes the TCP-client to get stuck again on method NetworkStream. Receive(…)
Solution: setting “DisableDHCPMediaSense”=1 in “ HKEY_LOCAL_MACHINE\Comm\Tcpip\Parms ”. This way no IP-addresses are requested whenever the Ethernet-Cable (RJ-45) is plugged out and plugged.
