C++ Console application not starting in debug after system reboot
I executed a simple C++ command line application.
Everything was ok.
After the weekend (and system reboot) I always get the following error (full log follows).
Can you please give me some direction?
My configuration:
  • Colibri iMX6DL 512MB v1.1Y
  • Iris V2.0A
  • TorizonCore Upstream 5.6.0+build.13 (dunfell)
  • Toradex Torizon Support v1.4.0
Loading application configuration...
Deployment started...
Device is not configured in project properties, prompting user to select a device.
Checking container state...
Container is not up to date, building it (this may take some time)...Step 1/12 : FROM --platform=linux/arm torizon/debian:2-bullseye
 ---> 045ef1b3dc3f
Step 2/12 : EXPOSE 2222
 ---> Using cache
 ---> cddc19eef74c
Step 3/12 : ARG SSHUSERNAME=torizon
 ---> Using cache
 ---> 69addadd23fe
Step 4/12 : ARG SSHUSERNAME=torizon
 ---> Using cache
 ---> 67cb7ee0c1a1
Step 5/12 : ENV DEBIAN_FRONTEND="noninteractive"
 ---> Using cache
 ---> 4367f66808ad
Step 6/12 : RUN touch /usr/bin/g++ &&     chmod +x /usr/bin/g++
 ---> Using cache
 ---> 7e9a0c4c6f14
Step 7/12 : RUN apt-get -q -y update     && apt-get -q -y install     openssl     openssh-server     rsync     libc-dev     gdb     zip     && rm -rf /var/lib/apt/lists/*
 ---> Using cache
 ---> ef9abbeea16e
Step 8/12 : COPY id_rsa.pub /id_rsa.pub
 ---> Using cache
 ---> 574fe2f8d3e5
Step 9/12 : RUN mkdir /var/run/sshd     && sed 's@session\s*required\s*pam_loginuid.so@session optional pam_loginuid.so@g' -i /etc/pam.d/sshd     && if test $SSHUSERNAME != root ; then mkdir -p /home/$SSHUSERNAME/.ssh ; else mkdir -p /root/.ssh ; fi     && if test $SSHUSERNAME != root ; then cp /id_rsa.pub /home/$SSHUSERNAME/.ssh/authorized_keys ; else cp /id_rsa.pub /root/.ssh/authorized_keys ; fi     && echo "PermitUserEnvironment yes" >> /etc/ssh/sshd_config     && echo "Port 2222" >> /etc/ssh/sshd_config     && su -c "env" $SSHUSERNAME > /etc/environment
 ---> Using cache
 ---> 2c7bd3bd7223
Step 10/12 : RUN rm -r /etc/ssh/ssh*key     && dpkg-reconfigure openssh-server
 ---> Using cache
 ---> 9dc084d036e8
Step 11/12 : RUN if [ ! -z "" ]; then     apt-get -q -y update     && apt-get -q -y install      && rm -rf /var/lib/apt/lists/* ;     fi
 ---> Using cache
 ---> d3150b815e77
Step 12/12 : CMD ["/usr/sbin/sshd", "-D"]
 ---> Using cache
 ---> 144d88e19bf2
Successfully built 144d88e19bf2
Successfully tagged cppconsoleexample_arm32v7-debian_bullseye_debug_28101187-f96c-41b8-89fa-e6b4c102b5c8:latest
Done
Deploying and starting remote container (it may take some time after a build or the first time you connect to a device)...Image on target is already up to date.
Done
Stopping current instance...
running startup script...
Starting new instance...
Done
Configuring project...
Successfully removed connection '-56392668;colibri-imx6-10918606 (username=torizon, port=32769, authentication=PrivateKey)'.
Warning: when the connection is not verified, the remote platform is not stored as attribute of the stored connection.
Successfully added connection '209146080;colibri-imx6-10918606 (username=torizon, port=32769, authentication=PrivateKey)'.
The authenticity of host 'colibri-imx6-10918606' can't be established.
ecdsa-sha2-nistp256 key fingerprint is SHA256:NltPbPqUqI4oVQCVe2Jjjf45piTSXebwgAvyUh23sIM.
Warning: accepted key for host 'colibri-imx6-10918606' (ecdsa-sha2-nistp256).
Successfully modified connection '209146080;colibri-imx6-10918606 (username=torizon, port=32769, authentication=PrivateKey)'.
sending incremental file list
created directory /home/torizon//CppConsoleExample
sent 23 bytes  received 67 bytes  60.00 bytes/sec
total size is 0  speedup is 0.00
Done
Error synchronizing folders from SDK container to target application. If you restarted the SDK container (or rebooted your machine) you may need to to a rebuild of the application before deploying and debugging it on the target.
Code: 529
Description: Remote command execution failed.
Message: Remote command rsync -rzv --delete -e "ssh -p 32769 -o \"StrictHostKeyChecking no\"" ~/CppConsoleExample/bin/x64/Debug_debian_arm32v7_bullseye/* torizon@colibri-imx6-10918606:~//CppConsoleExample/ returned error 23
Hi @Lorenzo ,
Could you try rebuilding your SDK container by pressing F1 then typing: Torizon: Rebuild SDK and reload in container?
If the above procedure doesn’t work you can try deleting the application binary/executable (usually a file with the same name as your project name) and all files ending with .o. After that run F1 → Torizon: Build debug container.
Let me know if this solves your problem.
Lucas Akira
Hi Lucas.
I am using the Visual Studio extension (no Visual Studio Code).
Before posting here I tried all sorts of rebuild and nothing worked.
But, as you suggested, by deleting the compilation output folder on my development machine seems to have fixed the problem.
Thanks!
Lorenzo
Glad I could help!
Lucas Akira
