Hello. I had the following problem. I’m trying to build the Linux kernel from the sources on my computer, guided by this article link text. But I get an error “Can’t locate strict.pm in @INC” What can I do with this?
make -j3 uImage LOADADDR=10008000 2>&1 | tee build.log
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CHK include/generated/bounds.h
CHK include/generated/asm-offsets.h
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CHK kernel/config_data.h
GEN lib/oid_registry_data.c
Can't locate strict.pm in @INC (you may need to install the strict module) (@INC contains: /home/dima/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/site_perl/5.22.1/ //usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/site_perl/5.22.1/ /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/site_perl/5.22.1 /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/vendor_perl/5.22.1/ /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/vendor_perl/5.22.1 /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/5.22.1/ /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/5.22.1 /usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/perl/5.22.1 .) at ./lib/build_OID_registry line 14.
BEGIN failed--compilation aborted at ./lib/build_OID_registry line 14.
make[1]: *** [lib/oid_registry_data.c] Error 2
make: *** [lib] Error 2
make: *** Waiting for unfinished jobs....
hello
Could you provide the version of the Bsp you are compiling? Which host distribution are u using?
Hello
Could you try using gcc6 instead of gcc5 as written in the article you are following to compile the kernel?
Image Version - 2.7 Kernel Git Branch - toradex_4.1-2.0.x-imx
Host:
Distro: angstrom
Distro Version: v2016.12
Metadata Revision: ddf907ca95a19f54785079b4396935273b3747f6
Timestamp: 20170629045849
Thanks for the Bsp version, but i wanted additionally Information about your Host. Thiis the PC you are using to compile the linux kernel and which you are using to connect to the target (module).
Further, Could you try using gcc6 instead of gcc5 as written in the article you are following to compile the kernel?
Thanks for the Bsp version of the module. Could you provide also details about your Host?
Could you use GCC6 instead of GCC5 to compile the Linux Kernel?
For building kernel I use
$ arm-angstrom-linux-gnueabi-gcc --version
arm-angstrom-linux-gnueabi-gcc (Linaro GCC 6.2-2016.11) 6.2.1
20161016
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There
is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
And this is my $PATH
$ echo $PATH
/home/dima/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin:/home/dima/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/:/opt/Qt5.5/5.5/gcc_64/bin:/opt/Qt5.5/5.5/gcc_64/bin:/opt/Qt5.5/5.5/gcc_64/bin:/usr/lib64/qt-3.3/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/sbin:/home/dima/bin
environment variables:
$ cat ~/export_compiler_imx6
export ARCH=arm
export PATH=/home/dima/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin:/home/dima/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/arm-angstrom-linux-gnueabi/:$PATH
export CROSS_COMPILE=arm-angstrom-linux-gnueabi-
To start building I use this command:
make apalis_imx6_defconfig
Hi
Note that building the kernel with an OE SDK that way works here. So the answer to Jasky’s question on the build host’s distribution might shed some light.
Also what is the output of the following:
find /usr/ -name strict.pm -exec ls -l {} \; 2>/dev/zero
And what is the output of the following (after sourcing your environment script):
echo "use strict;" > hello.pl
echo 'print "Hello World!\n";' >> hello.pl
perl hello.pl
/usr/bin/perl hello.pl
Max
I had found the reason, no longer relevant for me. Excuse for troubling.
Thanks for the feedback. What was the issue?
