Hi, may i know how to create a project solution and run application in Window CE 8 by using visual studio 2017? Thanks
Dear @TanJingSuan
I’m afraid VS2017 does not support application development for WEC2013 (Windows CE 8).
The latest version you can use is VS2015.
There’s a related post:
Regards
Andy
Hi, i currently installed app builder for visual studio, but not working and doesnt know why, thanks.
Btw, im currently try on visual studio 2013 now
Dear @TanJingSuan
Did you install the Application Builder for VS2017 or VS2013? (VS2017 does not support the Application Builder).
Regards, Andy
i have both visual studio 2017 and 2013, difference computer, and i tried on visual studio 2013 doesnt have the features of window ce after install AppBuilderSetup_VS2013_v60801
Dear @TanJingSuan
You also need to install at least one SDK. You can find our SDKs on the developer website:
After installing the SDK, you can create a new Windows CE project it in VS2013 (Templates → Visual C++ → Windows Embedded Compact or Templates → Visual C# → Windows Embedded Compact)
Regards, Andy
i am using with Visual studio 2015.
and .net CF, it’s working fine
for Silverlight you have to use visual studio 2008
May i know it should be install in the PC with OS Windows Embedded Compact 8? If im currently using window 7 or 10 can use Windows Embedded Compact SDK?
The error message shows must install window Embedded XAML tools
VS2008 does not support to be used for any Windows CE 8 (WEC2013) applications, neither native nor .NET applications.
Dear @TanJingSuan
Your development machine should always be a PC running Windows 7 or Windows 10 (not Windows Embedded Compact 8).
The problem you describe is a Microsoft bug. To solve it, you need to install the updates for Windows Embedded Compact 2013 on your PC. Please refer to the following Microsoft article for details:
Regards
Andy
I found this a better fix for the Embedded XAML Tools block in the version 2.3 SDK release:
