I need to run a custom script after wake-up on buildroot. I’m able to run it after the startup but I can’t figure out how to run a script after resume/wakeup.
Can you help me.
Matteo
Can you help me.
Matteo
Dear @matteo_s ,
Are you using Systemd? In that case, maybe this link is helpful: laptop - Writing a systemd service to be executed at resume - Unix & Linux Stack Exchange
Janani
Unfortunately I’m not using systemd. I just have init.d.
Dear @matteo_s ,
In that case, probably this technique mentioned in this link might do the trick: [all variants] HowTo run a script after RESUME [LUCID]
Janani
Unfortunately the directory mentioned in this thread is part of systemd initialisation… I need a solution when Busybox is the initialisation system.
Thank you,
Matteo
Dear @matteo_s
Do you use busybox sysvinit then? Unfortunately, we don’t know how the power management works there. Maybe you have some luck in the sources? SysVInit would allow to use /etc/pm as @saijanani.tx wrote… If busybox sysvinit doesn’t support that it’s unfortunately hard to support you. How do you put your system into suspend? Can’t you do just something like:
#!/bin/bash
do_before_suspend
# Probably echo 1 > /sys/..../suspend
do_after_suspend
Stefan
