I have the following error during building with Openembedded layers
ERROR: No recipes available for:
/home/ebers/oe-core/build/…/layers/meta-jetson-tk1/recipes-graphics/mesa/mesa_11.1.1.bbappend
/home/ebers/oe-core/build/…/layers/meta-angstrom/recipes-tweaks/ecj/ecj-initial-native.bbappend
If you build for Colibri iMX7 you could remove meta-jetson-tk1 and meta-toradex-tegra from your conf/bblayers.conf so that recipes and appends you don’t need are not parsed at all.
Alternatively you extend conf/local.conf with
BB_DANGLINGAPPENDS_WARNONLY = "true"
which demotes the message to a warning. Actually this is what surprises me because meta-toradex-bsp-common should already take care of setting this variable.
If that does not help I would need to know how you deviated from the setup described here. Also what versions of each layer are in use.
you are right, it seems to me the issue comes from version 2.7b3_20170630. With the last version 2.8 (Colibri-iMX7_LXDE-Image_2.8b4.129-20181005) this issue has not appeared.
Now I am having troubles with the v4l-utils during compiling:
arm-angstrom-Linux-gnueabi-g++: error: cec-ctl.cpp: No such file or directory
arm-angstrom-Linux-gnueabi-g++: fatal error: no input files
compilation terminated
ERROR: Task (/home/…/v4l-utils_1.12.3.bb:do_compile) failed with exit code ‘1’
