I’m converting a project from BSP 2.8 to TorizonCore. I have a device tree overlay that works with our hardware, and I’m trying to use TorizonCore Builder to build and deploy it. I’m following the instructions for building a device tree using TorizonCore Builder, but when I get to the step of running torizoncore-builder dt checkout, it fails as follows:
root@debian:/home/user/torizon# source ./tcb-env-setup.sh
You may have an outdated version installed. Would you like to check for updates online? [y/n] y
Setting up TorizonCore Builder with version 2.
Pulling TorizonCore Builder...
2: Pulling from torizon/torizoncore-builder
Digest: sha256:e5453981ba65a82eb4c0180ef2b0b91e457afcb2755eb77bb176328428c97e70
Status: Image is up to date for torizon/torizoncore-builder:2
Done!
Setup complete! TorizonCore Builder is now ready to use.
For more information, run 'torizoncore-builder -h' or go to https://developer.toradex.com/knowledge-base/torizoncore-builder-tool
root@debian:/home/user/torizon# torizoncore-builder dt checkout
An unexpected Exception occured. Please provide the following stack trace to
the Toradex TorizonCore support team:
File "/builder/torizoncore-builder", line 172, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/dt.py", line 36, in do_dt_checkout
checkout_git_repo(storage_dir, None, None)
File "/builder/tcbuilder/backend/common.py", line 281, in checkout_git_repo
git_branch = get_branch_from_metadata(storage_dir)
File "/builder/tcbuilder/backend/common.py", line 266, in get_branch_from_metadata
src_sysroot = ostree.load_sysroot(src_sysroot_dir)
File "/builder/tcbuilder/backend/ostree.py", line 40, in load_sysroot
sysroot.load()
gi.repository.GLib.GError: g-io-error-quark: loading sysroot: opendir(/storage/sysroot): No such file or directory (1)
Is there a step that I’m missing? Here’s the information on the host system:
root@debian:/home/user/torizon# uname -a
Linux debian 4.19.0-14-amd64 #1 SMP Debian 4.19.171-2 (2021-01-30) x86_64 GNU/Linux
root@debian:/home/user/torizon# lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
