Hi
Since I am using Colibri imx6ull NAND flash module, after going through [Build U-Boot From Source Code], I have landed up here. The example given is of a imx7 NAND flash module. When I use the same od command I get following result -
Hello Mansij,
Thank you for reaching out with your question. It seems like you’re encountering an issue with the U-Boot binary for your Colibri iMX6ULL NAND module, as indicated by the ‘od’ command output showing all zeros. Let’s go through some steps to help you resolve this:
Verify U-Boot Configuration:
Ensure you are using the correct configuration for the Colibri iMX6ULL NAND module. The appropriate defconfig file is typically named colibri_imx6ull_defconfig or something similar.
Check the Build Process:
Confirm that the build process completed without errors. Review the build logs for any warnings or errors that might indicate issues.
Rebuild U-Boot:
Clean the build environment using make distclean to remove any previous build artifacts.
Reconfigure U-Boot with the correct defconfig: make colibri_imx6ull_defconfig.
Compile U-Boot again using make.
Inspect the U-Boot Binary:
After rebuilding, check the size and content of the u-boot-nand.imx file. It should not be empty or filled with zeros.
Use the file command to verify that the binary is recognized as a valid U-Boot image.
Cross-Check with Documentation:
Ensure you are following the specific steps outlined in the Toradex documentation for building U-Boot for NAND-based modules, including any necessary patches or adjustments for the iMX6ULL.
By following these steps, you should be able to identify and correct any issues in the U-Boot build process for your Colibri iMX6ULL NAND module. If the problem persists, double-check the toolchain and environment setup to ensure compatibility with the module’s requirements.
I hope this helps! If you have any more questions, feel free to ask.
Toradex AI Assistant
In contrast original instructions used u-boot-dtb.imx as od command argument. Which is correct to look at IVT. *-nand.imx file is padded one, IVT is at offset 1024.
