Build TorizonOS in Azure pipeline
I started updating how my Azure pipleine uses torizoncore-builder.
If I understood, the preferred way is now using the container torizonextras/torizon-dev as done by github workflow and gitlab automation.
Inside this container everything should be already available and created (xonsh, …).
Am I right?
The problem is that this container cannot start in Azure Devops pipeline, with the following error log:
Status: Downloaded newer image for torizonextras/torizon-dev:dev
Final exit code for Docker pull: 0
/usr/bin/docker info -f “{{range .Plugins.Network}}{{println .}}{{end}}”
bridge
host
ipvlan
macvlan
null
overlay
/usr/bin/docker network create --label f63c4c vsts_network_aecd63d112f04a268fedec70eb29e396
3eccdb092ba70aa486f3895ddeaf1d298147d07bb8ed3407d6b5d93bc657d60f
/usr/bin/docker inspect --format=“{{index .Config.Labels "com.azure.dev.pipelines.agent.handler.node.path"}}” torizonextras/torizon-dev:dev
/usr/bin/docker create --name a0dc1085c29e49478c8416c89591b478_torizonextrastorizondevdev_608e91 --label f63c4c --network vsts_network_aecd63d112f04a268fedec70eb29e396 --user root -v “/var/run/docker.sock”:“/var/run/docker.sock” -v “/home/vsts/work/1”:“/__w/1” -v “/home/vsts/work/_temp”:“/__w/_temp” -v “/home/vsts/work/_tasks”:“/__w/_tasks” -v “/opt/hostedtoolcache”:“/__t” -v “/home/vsts/actions-runner/cached/4.270.0/externals”:“/__a/externals”:ro -v “/home/vsts/work/.taskkey”:“/__w/.taskkey” torizonextras/torizon-dev:dev bash -c “‘/__a/externals/node20_1/bin/node’ --version && echo ‘container-startup-using-node-20’ && ‘/__a/externals/node20_1/bin/node’ -e ‘setInterval(function(){}, 24 * 60 * 60 * 1000);’ || ‘/__a/externals/node16/bin/node’ --version && echo ‘container-startup-using-node-16’ && ‘/__a/externals/node16/bin/node’ -e ‘setInterval(function(){}, 24 * 60 * 60 * 1000);’ || echo ‘container-startup-failed’”
4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1
DockerActionRetries variable value: True
/usr/bin/docker start 4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1
Final exit code for Docker start: 0
/usr/bin/docker ps --all --filter id=4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1 --filter status=running --no-trunc --format “{{.ID}} {{.Status}}”
4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1 Up Less than a second
/usr/bin/docker logs --details 4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1
usage: zygote [-h] [–version] {scan,target,connect,new,init,tasks,fetch} …
zygote: error: argument {scan,target,connect,new,init,tasks,fetch}: invalid choice: ‘bash’ (choose from ‘scan’, ‘target’, ‘connect’, ‘new’, ‘init’, ‘tasks’, ‘fetch’)
##[warning]Container startup timeout after 10100ms. Cannot get startup status from container.
/usr/bin/docker exec  4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1 sh -c "command -v bash"
##[error]Docker-exec executed: `sh -c "command -v bash"`; container id: `4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1`; exit code: `1`; command output: `Error response from daemon: container 4860247cec64091f341f86349e4c65f3b1ae73c218fbb507aeef34541ad6d2e1 is not running`
How can I fix this?
The issue you’re experiencing is related to Azure DevOps trying to execute bash within the torizonextras/torizon-dev container, but the container’s entrypoint is configured to use zygote instead (1).
Solution
Based on community discussions, there are several approaches to resolve this:
Option 1: Use the script Command Wrapper
You can wrap your torizoncore-builder commands with the script command to simulate a TTY environment (1):
script -q -c "torizoncore-builder build"
(1)
Option 2: Manual Alias Definition
Instead of relying on the container’s setup script, define the torizoncore-builder alias manually in your pipeline (1). This approach avoids the TTY-related issues entirely.
Option 3: Modify the Setup Script
Some users have successfully used sed to remove the -it flag from the setup script before running it (1). This removes the interactive terminal requirement that causes issues in CI/CD environments.
Alternative Approach
For Azure DevOps specifically, consider using a different container approach or running TorizonCore Builder directly on the host system. The documentation shows that TorizonCore Builder can be used effectively in CI/CD pipelines, but the specific container configuration needs to match your pipeline’s execution model (2).
The error you’re seeing (zygote: error: argument {scan,target,connect,new,init,tasks,fetch}: invalid choice: 'bash') indicates that Azure DevOps is trying to execute bash commands directly against the container’s entrypoint, which expects zygote commands instead.
Greetings @vix,
How exactly are you invoking torizonextras/torizon-dev in your pipeline? Based on your logs it looks like you’re doing something like docker run torizonextras/torizon-dev:dev bash. Due to the presence of the error:
Am I right?
The container here provides an environment similar to what is found in the IDE extension. To allow the execution of various xonsh scripts and tasks for automation.
