I try to build the device tree mainly to enable the atmel touch driver (First Steps with Capacitive Touch Display 7" Parallel | Toradex Developer Center).
I am following this guide: Build From Source Code Documentation Overview | Toradex Developer Center
I can successfully build U-Boot and the Linux kernel, but it fails to build the device tree ($ make DTC_FLAGS=“-@” imx6q-apalis-eval.dtb):
**dtc: invalid option -- '@' **
Below is a copy of the terminal output. I am using Ubuntu 16.04 with DTC 1.4.1, so I have installed 1.6.0 from source (I have tried different versions, same issue).
kb@kb-vb:~$ export ARCH=arm
kb@kb-vb:~$ export DTC_FLAGS="-@"
kb@kb-vb:~$ export PATH=~/gcc-linaro/bin/:$PATH
kb@kb-vb:~$ export CROSS_COMPILE=arm-linux-gnueabihf-
kb@kb-vb:~$ dtc -v
Version: DTC 1.4.1-g47216cdb
kb@kb-vb:~$ cd dtc
kb@kb-vb:~/dtc$ export PATH=$HOME/dtc/:$PATH
kb@kb-vb:~/dtc$ cd
kb@kb-vb:~$ dtc -v
Version: DTC 1.6.0
kb@kb-vb:~$ cd linux-toradex/
kb@kb-vb:~/linux-toradex$ make apalis_imx6_defconfig
# configuration written to .config
kb@kb-vb:~/linux-toradex$ make DTC_FLAGS="-@" imx6q-apalis-eval.dtb
scripts/kconfig/conf --silentoldconfig Kconfig
DTC arch/arm/boot/dts/imx6q-apalis-eval.dtb
./scripts/dtc/dtc: invalid option -- '@'
Usage: dtc [options]
Options: -[qI:O:o:V:d:R:S:p:fb:i:H:sW:E:hv]
-q, --quiet
Quiet: -q suppress warnings, -qq errors, -qqq all
-I, --in-format
Input formats are:
dts - device tree source text
dtb - device tree blob
fs - /proc/device-tree style directory
-o, --out
Output file
-O, --out-format
Output formats are:
asm - assembler source
-V, --out-version
Blob version to produce, defaults to 17 (for dtb and asm output)
-d, --out-dependency
Output dependency file
-R, --reserve
Make space for <number> reserve map entries (for dtb and asm output)
-S, --space
Make the blob at least <bytes> long (extra space)
-p, --pad
Add padding to the blob of <bytes> long (extra space)
-b, --boot-cpu
Set the physical boot cpu
-f, --force
Try to produce output even if the input tree has errors
-i, --include
Add a path to search for include files
-s, --sort
Sort nodes and properties before outputting (useful for comparing trees)
-H, --phandle
Valid phandle formats are:
legacy - "linux,phandle" properties only
epapr - "phandle" properties only
both - Both "linux,phandle" and "phandle" properties
-W, --warning
Enable/disable warnings (prefix with "no-")
-E, --error
Enable/disable errors (prefix with "no-")
-h, --help
Print this help and exit
-v, --version
Print version and exit
Error: unknown option
scripts/Makefile.lib:313: recipe for target 'arch/arm/boot/dts/imx6q-apalis-eval.dtb' failed
make[1]: *** [arch/arm/boot/dts/imx6q-apalis-eval.dtb] Error 1
arch/arm/Makefile:336: recipe for target 'imx6q-apalis-eval.dtb' failed
make: *** [imx6q-apalis-eval.dtb] Error 2
kb@kb-vb:~/linux-toradex$ echo $PATH
/home/kb/dtc/:/home/kb/gcc-linaro/bin/:/home/kb/bin:/home/kb/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/kb/u-boot-toradex/tools:/home/kb/u-boot-toradex/tools
What is wrong here?
Thank you for your help!
