Having started a brand new machine to compile 2.6 on, following the OpenEmbedded tutorial.
repo init -b LinuxImageV2.6
repo sync -j1 (had some git issues)
ran . export and edited local.conf to MACHINE=apalis-imx6
When I try to build any recipe, I get the following error?
matthew@matthew-Lenovo-G780:~/oe-core/build$ bitbake angstrom-lxde-image
ERROR: OE-core’s config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
Please install the following missing utilities: makeinfo
libsdl-native is set to be ASSUME_PROVIDED but sdl-config can’t be found in PATH. Please either install it, or configure qemu not to require sdl.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Any Help appreciated please?
