Bug in Torizon vscode extension
I have been testing the Torizon vscode extension to create multi-root docker-compose (create-multi-root-docker-compose.xsh) , and I have found a behaviour that seems to be a bug.
If I have a container with a network, eg:
services:
  http_tts_en:
    build:
      context: .
      dockerfile: Dockerfile
    image: ${DOCKER_LOGIN}/http_tts_en:${TAG}
    devices:
      - /dev/snd:/dev/snd
    profiles:
      - release
    networks:
      tts_net:
        aliases:
          - http_tts_en
networks:
  tts_net: null
and if I call the routine create-production-docker-compose found in .conf/create-multi-root-docker-compose.xsh, then the line
networks:
  tts_net:
will not included in the final docker-compose.prod.yml
Every time I call the create-production-docker-compose, I need to manually add the missing 2 lines, otherwise I cannot launch my docker compose
Hello @rafdelpilotfish,
Which version of Torizon IDE extension and VSCode are you using? Also, if you started the project from one of our templates, could you please specify which one it is?
Thanks for reporting this.
Do you still face this issue?
Could you give me an update on the current status?
Bruno
