Bug: Cog container missing shared-mime-info package
The Torizon build of the Cog container is missing the shared-mime-info package.
This means it will fail to render any content using a file:/// URI that are local and you only see raw HTML.
To reproduce: Run Cog with e.g a volume mount to some local HTML files (/startup/index.html) and pass one of them as the starting URL, file:///startup/index.html
See: Cog fails to render local html file. · Issue #73 · Igalia/cog · GitHub
Thank you for reporting, we’ll include the share-mime-info package in the next patch release of Cog.
