BSP 5.7.2 source codeが欲しい
To obtain the BSP 5.7.2 source code for Toradex modules, you can follow these general steps:
Check the Embedded Linux Release Matrix: This will provide you with the version information of the Linux kernel, U-Boot, Yocto/OpenEmbedded, the Toradex BSP, and Linux images, along with release dates.
Fetch the Source Code:
- For the Linux kernel, you can obtain the source code using Git. The specific branch or tag you need will depend on the module type and BSP version.
- For U-Boot, you can also obtain the source code using Git. The repository and branch/tag will depend on whether your module is upstream-based or downstream-based.
Git Repositories:
- Linux Kernel: For upstream-based modules, you can fetch the kernel from the mainline Linux repository. For downstream-based modules, you can fetch it from Toradex’s repository.
- U-Boot: For upstream-based modules, fetch from
https://gitlab.com/u-boot/u-boot.git. For downstream-based modules, fetch fromhttps://git.toradex.com/u-boot-toradex.git.
Example Commands:
- Linux Kernel:
git clone -b toradex_5.7.2 https://git.toradex.com/linux-toradex.git - U-Boot:
git clone -b toradex_5.7.2 https://git.toradex.com/u-boot-toradex.git
- Linux Kernel:
Apply Patches: If you are working with upstream-based modules, you may need to apply specific patches.
Build and Deploy: Follow the instructions for building and deploying the kernel and U-Boot as described in the provided documentation.
If you need more specific instructions tailored to your module, please refer to the detailed steps in the Toradex documentation or the “Additional Module-specific Steps” section for your particular SoM (System on Module).
