Hi!
I’m trying to build the angstrom-lxde-image from BSP 2.8 using Yocto with the MACHINEOVERRIDES .= ":use-mainline-bsp" definition in local.conf to enable the Etnaviv graphics driver.
After disabling the backports package, which was causing a compile error, the build fails on the do_rootfs task outputting the following log:
ERROR: angstrom-lxde-image-2.8b6-r0 do_rootfs: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
0001:
*** 0002:license_create_manifest(d)
0003:
File: '/oe-docker/2.8-oe-core/build/../layers/openembedded-core/meta/classes/license.bbclass', lineno: 48, function: license_create_manifest
0044: pkg_dic = {}
0045: for pkg in sorted(image_list_installed_packages(d)):
0046: pkg_info = os.path.join(d.getVar('PKGDATA_DIR'),
0047: 'runtime-reverse', pkg)
*** 0048: pkg_name = os.path.basename(os.readlink(pkg_info))
0049:
0050: pkg_dic[pkg_name] = oe.packagedata.read_pkgdatafile(pkg_info)
0051: if not "LICENSE" in pkg_dic[pkg_name].keys():
0052: pkg_lic_name = "LICENSE_" + pkg_name
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/oe-docker/2.8-oe-core/build/tmp-glibc/pkgdata/colibri-imx6/runtime-reverse/kernel-4.9.166-2.8.6+gd899927'
ERROR: angstrom-lxde-image-2.8b6-r0 do_rootfs: Function failed: license_create_manifest
ERROR: Logfile of failure stored in: /oe-docker/2.8-oe-core/build/tmp-glibc/work/colibri_imx6-angstrom-linux-gnueabi/angstrom-lxde-image/2.8b6-r0/temp/log.do_rootfs.3056613
ERROR: Task (/oe-docker/2.8-oe-core/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-lxde-image.bb:do_rootfs) failed with exit code '1'
In this excerpt, I notice that the task refers to the wrong kernel version. With the mainline-bsp option, the kernel version should be higher than the 4.9.166:
Any tips on this?
Thanks,
Gustavo.
