Hello
I’d like to use a simple Browser on my Colibri IMX8DX 1GB V1.0D SOM with custon board using yocto reference image.
I followed your instructions here: How to Use Web Browser (Linux) | Toradex Developer Center
Both browser (COG and Chromium) are working, but performance is bad.
Looks like there is a CPU-Usage problem with COG and a RAM-Usage problem with Chromium (with GPU hardware acceleration).
I think for Chromium only solution is using IMX8QX with 2GB, right? Do you have tested Chromium on IMX8QX?
Is it possible to use COG with GPU hardware acceleration? Do you know any other solution or lightweight browser example running on Colibri-IMX8DX 1GB? Or do I have to switch hardware?
Thanks!!
Immanuel
