Hello..
Trying to find out 1. bootup time & 2. wakeup time of device after sleep.
Please advise.
Thanks,
Shardul
Tried echo mem > /sys/power/state for apalis imx8
output : -sh: / sys/power/state permission denied
Is there any other way to put processor in sleep from command line
Thanks.
Hi @ShardulC
Welcome to Toradex community.
Could you provide software and hardware versions of your setup?
Hardware: Apalis imx8QM 4GB WB IT V1.1 on eval board 06805227
Software: Torizon
Thanks.
Hello @ashok.tx Any update about sleep & wakeup functionalities for imx8 board
Thanks.
Hi @ShardulC
- bootup time & 2. wakeup time of device after sleep.
systemd-analyze help you to get the boot time statistics.
ok, Thanks @ashok.tx . Using systemd-analyze I get something around 3.8 seconds for kernel and 38.4 for userspace.
Now for putting system in sleep I tried
echo mem > /sys/power/state and the output is -sh: sys/power/state permission denied
is there any work around to put system in sleep and wake it up.
Thanks.
Hi @ShardulC
Could you check with the sudo -i and then echo mem > /sys/power/state.sudo -i allows you to login as a root user.
tried with sudo -i but getting the same output: permission denied..
Hi @ShardulC
It works smoothly in my setup
apalis-imx8-06548495 login: torizon
Password:
apalis-imx8-06548495:~$ sudo -i
Password:
root@apalis-imx8-06548495:~# echo mem > /sys/power/state
