Hello everyone,
I tried to load easy installer from USB as guided here: Load Easy Installer From External Media (SD Card/USB Stick) | Toradex Developer Center . Unfortunately U-Boot cannot find my USB stick with easy installer:
U-Boot 2020.04-5.7.2+git.33bb8e968332 (Jul 06 2022 - 12:21:53 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 42C
Reset cause: POR
DRAM: 4 GiB
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Verdin iMX8M Plus Quad 4GB IT V1.1A, Serial# 14871342
Carrier: Toradex Dahlia V1.1C, Serial# 11048795
BuildInfo:
- ATF 2fa8c63
- U-Boot 2020.04-5.7.2+git.33bb8e968332
Setting variant to nonwifi
flash target is MMC:2
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
Verdin iMX8MP # usb start
starting USB...
Bus usb@38100000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@38200000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@38100000 for devices... 1 USB Device(s) found
scanning bus usb@38200000 for devices... 5 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
Verdin iMX8MP #
I tried both usb ports of X4 Dahlia connector but with no success. Then tried with SDCard with bootcmd_mmc1
it booted to easy installer like a charm.
Additional question - i wanted to flash emmc (in this case mmc2) with new yocto image on USB storage device (kernel, dts and rootfs) generated like here Boot From an SD Card / USB Stick | Toradex Developer Center using only U-boot flash write commands. How it should be done? I dont want to use combo recovery / easy installer because for my application only serial port and USB ports will be available.
