Hi everybody
I am using Apalis imx6 1GB with Apalis Evaluation board.
I have downloaded the Boot2Qt image and extract on an SD card and started the easy installer.
Due to documents, I have installed Boot2Qt successfully and I have terminal via USB serial port as well.
My problem is about VGA display. I don’t have an LCD module and I need to work with this product via VGA display.
According to this link env has set like below:
setenv vidargs video=mxcfb0:dev=vdac,1280x720M@60,if=RGB24 fbmem=32M
but there is no any activity on VGA display at all.
Do you have any idea?
