Boot Failure After Upgrade
Followed the instructions at Quickstart Guide | Toradex Developer Center
After flashing the new image, the reboot (and subsequent reboots) fails. The update and boot sequence follows:
U-Boot 2016.11-2.7.4+g1b121c6 (Oct 06 2017 - 22:43:32 +0000)
TEGRA124
DRAM:  2 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis TK1 2GB V1.1A, Serial# 02937893
Net:   No ethernet found.
Apalis TK1 #
Apalis TK1 # run setupdate
reading flash_blk.img
710 bytes read in 14 ms (48.8 KiB/s)
710 bytes read in 13 ms (52.7 KiB/s)
## Executing script at 81000000
reading apalis-tk1/flash_blk.img
2598 bytes read in 20 ms (126 KiB/s)
enter "run update" to update the entire module
Apalis TK1 # run update
reading apalis-tk1/apalis-tk1.img
593920 bytes read in 46 ms (12.3 MiB/s)
switch to partitions #1, OK
mmc0(part 1) is current device
MMC write: dev # 0, block # 0, count 1160 ... 1160 blocks written: OK
reading apalis-tk1/mbr.bin
512 bytes read in 14 ms (35.2 KiB/s)
switch to partitions #0, OK
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
reading apalis-tk1/boot.vfat
16777216 bytes read in 774 ms (20.7 MiB/s)
MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK
reading apalis-tk1/uImage
5481968 bytes read in 264 ms (19.8 MiB/s)
writing uImage
5481968 bytes written
reading apalis-tk1/tegra124-apalis-eval.dtb
50101 bytes read in 26 ms (1.8 MiB/s)
writing tegra124-apalis-eval.dtb
50101 bytes written
reading apalis-tk1/root.ext4-100
67108864 bytes read in 3029 ms (21.1 MiB/s)
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-101
67108864 bytes read in 3028 ms (21.1 MiB/s)
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-102
67108864 bytes read in 3033 ms (21.1 MiB/s)
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-103
MMC write: dev # 0, block # 434176, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-104
MMC write: dev # 0, block # 565248, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-105
MMC write: dev # 0, block # 696320, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-106
MMC write: dev # 0, block # 827392, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-107
MMC write: dev # 0, block # 958464, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-108
MMC write: dev # 0, block # 1089536, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-109
67108864 bytes read in 3030 ms (21.1 MiB/s)
MMC write: dev # 0, block # 1220608, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-110
MMC write: dev # 0, block # 1351680, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-111
67108864 bytes read in 3034 ms (21.1 MiB/s)
MMC write: dev # 0, block # 1482752, count 131072 ... 131072 blocks written: OK
reading apalis-tk1/root.ext4-112
42991616 bytes read in 1944 ms (21.1 MiB/s)
MMC write: dev # 0, block # 1613824, count 83968 ... 83968 blocks written: OK
resetting ...
TEGRA124
DRAM:  2 GiB
In:    serial
Out:   serial
Err:   serial
Booting from internal eMMC chip...
reading tegra124-apalis-eval.dtb
50101 bytes read in 16 ms (3 MiB/s)
reading uImage
5481968 bytes read in 139 ms (37.6 MiB/s)
## Booting kernel from Legacy Image at 81000000 ...
   Image Name:   Linux-3.10.40-2.7.4+ge963625
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    5481904 Bytes = 5.2 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Loading Kernel Image ... OK
   Using Device Tree in place at 82000000, end 8200f3b4
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.40-2.7.4+ge963625 (yocto@f074f422a215) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Fri Oct 6 23:10:37 UTC 2017
[    0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=30c7387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: apalis-tk1, model: Toradex Apalis TK1 on Apalis Evaluation Board, serial: 0
[    0.000000] Tegra reserved memory:
[    0.000000] LP0:                    f46ff000 - f46ff80f
[    0.000000] Bootloader framebuffer: 00000000 - 00000000
[    0.000000] Bootloader framebuffer2: 00000000 - 00000000
[    0.000000] Framebuffer:            fa500000 - fb6fffff
[    0.000000] 2nd Framebuffer:        fb700000 - ffefffff
[    0.000000] Carveout:               00000000 - 00000000
[    0.000000] Vpr:                    00000000 - 00000000
[    0.000000] Tsec:                   00000000 - 00000000
[    0.000000] cma: CMA: reserved 16 MiB at ae800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] DTS File Name: /workdir/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/arch/arm/boot/dts/tegra124-apalis-eval.dts
[    0.000000] Tegra12: CPU Speedo value 2301, Soc Speedo value 2292, Gpu Speedo value 2110
[    0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[    0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[    0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[    0.000000] tegra: PLLP fixed rate: 408000000
[    0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[    0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[    0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[    0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[    0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[    0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[    0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[    0.000000] Lowering se maximum rate from 600000000 to 480000000
[    0.000000] Lowering vde maximum rate from 600000000 to 480000000
[    0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[    0.000000] Lowering vi maximum rate from 700000000 to 600000000
[    0.000000] Lowering isp maximum rate from 700000000 to 600000000
[    0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[    0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[    0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[    0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[    0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[    0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[    0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[    0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[    0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[    0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[    0.000000] Switching to timer-based delay loop
[    0.000000] tegra_powergate_init: DONE
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1c2e000 s15156 r8192 d13516 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 498960
[    0.000000] Kernel command line: lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 ip=off root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait igb_mac=00:14:2d:2c:d4:25 consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 video=tegrafb0:640x480-16@60 fbcon=map:1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1955MB = 1955MB total
[    0.000000] Memory: 1955624k/1955624k available, 140504k reserved, 1223676K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc09f2778   (10154 kB)
[    0.000000]       .init : 0xc09f3000 - 0xc0a66b34   ( 463 kB)
[    0.000000]       .data : 0xc0a68000 - 0xc0b55bb0   ( 951 kB)
[    0.000000]        .bss : 0xc0b55bb0 - 0xc0bf0db8   ( 621 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:960
[    0.000000] the number of interrupt controllers found is 5
[    0.000000] Architected local timer running at 12.00MHz (phys).
[    0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[    0.000000] Ignoring duplicate/late registration of read_current_timer delay
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.003579] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[    0.003649] pid_max: default: 32768 minimum: 301
[    0.004001] Mount-cache hash table entries: 512
[    0.024924] Initializing cgroup subsys debug
[    0.024968] Initializing cgroup subsys freezer
[    0.025050] CPU: Testing write buffer coherency: ok
[    0.025124] ftrace: allocating 30371 entries in 60 pages
[    0.065497] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.065537] Setting up static identity map for 0xc0726978 - 0xc0726a08
[    0.069537] ftrace: Allocated trace_printk buffers
[    0.076232] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.079251] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.082279] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.082411] Brought up 4 CPUs
[    0.082471] SMP: Total of 4 processors activated.
[    0.082487] CPU: All CPU(s) started in SVC mode.
[    0.083583] devtmpfs: initialized
[    0.092416] pinctrl core: initialized pinctrl subsystem
[    0.092811] regulator-dummy: no parameters
[    0.093681] NET: Registered protocol family 16
[    0.096020] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.097304] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[    0.098373] console [pstore-1] enabled
[    0.098412] ramoops: attached 0x200000@0xfa300000, ecc: 0/0
[    0.098827] cpuidle: using governor ladder
[    0.098850] cpuidle: using governor menu
[    0.102216] apalis_tk1_camera_auxdata: update camera lookup table.
[    0.111516] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[    0.111963] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[    0.119525] Wake16 for irq=34
[    0.122150] Wake58 for irq=81
[    0.122199] Wake41 for irq=129
[    0.122217] Wake43 for irq=129
[    0.122263] Wake40 for irq=53
[    0.122280] Wake42 for irq=53
[    0.125398] Selecting UARTA as the debug console
[    0.125445] The debug console clock name is uarta
[    0.127374] PMC DT attribute sysclkreq_high=0, board value=1
[    0.127400] PMC DT attribute corereq_high=0, board value=1
[    0.127422] PMC DT attribute cpu_off_timer=0, board value=300
[    0.127443] PMC DT attribute cpu_timer=0, board value=500
[    0.127464] PMC DT attribute suspend_mode=0, board value=2
[    0.127934] Clear bootloader IO dpd settings
[    0.128093] Loading Apalis TK1 EMC tables.
[    0.128354] tegra: pll_m is selected as scalable EMC clock source
[    0.128399] Lowering emc maximum rate from 1200000000 to 924000000
[    0.128427] tegra: validated EMC DFS table
[    0.128504] apalis_tk1_edp_init: CPU regulator 12500 mA
[    0.384915] apalis_tk1_edp_init: GPU regulator 11400 mA
[    0.385892] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[    0.385913] swapper/0 isomgr_init(): max_iso_bw=7392000KB[    0.473119] platform tegradc.0: IOVA linear map 0x00000000fa500000(1200000)
[    0.476477] platform tegradc.0: IOVA linear map 0x00000000fb700000(4800000)
[    0.481511] platform tegradc.1: IOVA linear map 0x00000000fa500000(1200000)
[    0.484863] platform tegradc.1: IOVA linear map 0x00000000fb700000(4800000)
[    0.485706] FUSE: cp_rev 0 ft_rev 0
[    0.485888] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[    0.486128] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.486157] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.486490] mc-err: Started MC error interface!
[    0.497224] bio: create slab <bio-0> at 0
[    0.498506] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[    0.498542] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[    0.498680] +V3.3_MXM: 3300 mV
[    0.499537] SCSI subsystem initialized
[    0.499942] usbcore: registered new interface driver usbfs
[    0.500017] usbcore: registered new interface driver hub
[    0.500131] usbcore: registered new device driver usb
[    0.504335] Wake18 for irq=118
[    0.505319] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x05
[    0.505349] as3722 4-0040: Device version 1V1 and platform version 1V2
[    0.505375] as3722 4-0040: Final OTP version 1V2
[    0.506215] Wake18 for irq=118
[    0.509341] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[    0.509563] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.509627] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.509684] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.509718] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.509750] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.509782] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.509854] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.509886] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.509918] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.509995] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.510027] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.510058] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.510090] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.510121] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.510156] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.510187] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.510218] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.510250] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.510282] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[    0.510333] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[    0.510366] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[    0.510398] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[    0.510429] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[    0.510460] as3722-regulator as3722-regulator.0: Consumer c16 does not have device name
[    0.510497] as3722-regulator as3722-regulator.0: Consumer c19 does not have device name
[    0.510528] as3722-regulator as3722-regulator.0: Consumer c20 does not have device name
[    0.510560] as3722-regulator as3722-regulator.0: Consumer c21 does not have device name
[    0.510591] as3722-regulator as3722-regulator.0: Consumer c22 does not have device name
[    0.510670] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.510702] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.510760] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.510792] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.510823] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.510854] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.510885] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.510917] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.510948] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.510979] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.511010] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.511064] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.511142] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.511174] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.511205] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.511239] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[    0.511294] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.511366] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.511399] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.511430] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.511483] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.512445] +VDD_CPU_AP: 650 <--> 1300 mV at 1000 mV 3500 mA
[    0.513223] +VDD_CORE: applied init 1150000uV constraint
[    0.513826] +VDD_CORE: 700 <--> 1350 mV at 1150 mV 3500 mA
[    0.514995] +V1.35_VDDIO_DDR(sd2): 1350 mV
[    0.515324] as3722-sd3: no parameters
[    0.515670] +V1.05: 1050 mV
[    0.516539] +V1.8: 1800 mV
[    0.516917] +VDD_GPU_AP: applied init 1000000uV constraint
[    0.517794] +VDD_GPU_AP: 650 <--> 1200 mV at 1000 mV 3500 mA
[    0.518309] +V1.05_AVDD: 1050 mV at 300 mA
[    0.519158] VDDIO_SDMMC1: 1800 <--> 3300 mV at 3300 mV at 150 mA
[    0.519829] +V1.2: 1200 mV at 150 mA
[    0.521069] +V1.05_RTC: 1000 mV at 150 mA
[    0.521546] AVDD_LVDS0_PLL: applied init 1800000uV constraint
[    0.521584] AVDD_LVDS0_PLL: 1800 <--> 3300 mV at 1800 mV at 150 mA
[    0.521928] as3722-ldo5: at 150 mA
[    0.522290] VDDIO_SDMMC3: 1800 <--> 3300 mV at 150 mA
[    0.522660] as3722-ldo7: at 150 mA
[    0.523323] +V3.3_ETH(ldo9): 3300 mV at 150 mA
[    0.523837] +V3.3_ETH(ldo10): 3300 mV at 150 mA
[    0.524325] +V1.8_VPP_FUSE: 1800 mV at 150 mA
[    0.525415] Linux video capture interface: v2.00
[    0.525473] pps_core: LinuxPPS API ver. 1 registered
[    0.525494] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.525558] PTP clock support registered
[    0.526381] Advanced Linux Sound Architecture Driver Initialized.
[    0.527359] +V1.05_AVDD_HDMI_PLL: 1050 mV
[    0.527414] +V1.05_AVDD_HDMI_PLL: supplied by +V1.05
[    0.527658] reg-fixed-sync-voltage 2.regulator: Consumer c7 does not have device name
[    0.527694] reg-fixed-sync-voltage 2.regulator: Consumer c8 does not have device name
[    0.527733] reg-fixed-sync-voltage 2.regulator: Consumer c11 does not have device name
[    0.527773] reg-fixed-sync-voltage 2.regulator: Consumer c15 does not have device name
[    0.527805] reg-fixed-sync-voltage 2.regulator: Consumer c16 does not have device name
[    0.527836] reg-fixed-sync-voltage 2.regulator: Consumer c17 does not have device name
[    0.527868] reg-fixed-sync-voltage 2.regulator: Consumer c18 does not have device name
[    0.528623] +V3.3: 3300 mV
[    0.528898] reg-fixed-sync-voltage 3.regulator: Consumer c3 does not have device name
[    0.529035] 5V_SW: 5000 mV
[    0.529358] VCC_USBO1: 5000 mV
[    0.529719] VCC_USBH(2A|2C|2D|3|4): 5000 mV
[    0.529897] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[    0.529932] reg-fixed-sync-voltage 6.regulator: Consumer c2 does not have device name
[    0.530092] BKL1_ON: 3300 mV
[    0.533110] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[    0.535588] tegra: failed to map regulator to power detect cell pwrdet_cam(-517)
[    0.535628] tegra: failed to map regulator to power detect cell pwrdet_pex_ctl(-517)
[    0.535981] tegra: failed regulators mapping - io power detection is left always on
[    0.536012] Switching to clocksource arch_sys_counter
[    0.558342] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.558523] nvmap_page_pool_init: Total MB RAM: 1925
[    0.558547] nvmap_page_pool_init: nvmap page pool size: 61625 pages (240 MB)
[    0.558699] nvmap_background_zero_thread: PP zeroing thread starting.
[    0.558871]  iram: dma coherent mem declare 0x0000000040001000,258048
[    0.559718] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[    0.559881] nvmap:inner cache maint threshold=2097152
[    0.569976] Wake39 for irq=52
[    0.570089] tegra-otg tegra-otg: otg transceiver registered
[    0.570451] NET: Registered protocol family 2
[    0.571246] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.571449] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.571641] TCP: Hash tables configured (established 8192 bind 8192)
[    0.571702] TCP: reno registered
[    0.571727] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.571783] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.572162] NET: Registered protocol family 1
[    0.572576] RPC: Registered named UNIX socket transport module.
[    0.572600] RPC: Registered udp transport module.
[    0.572620] RPC: Registered tcp transport module.
[    0.572639] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.572935] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[    0.578744] host1x host1x: initialized
[    0.579908] CPU PMU: probing PMU on CPU 0
[    0.579944] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[    0.580594] tegra_throttle : init passed
[    0.580714] Tegra cpuquiet initialized: disabled
[    0.580860] cpu-tegra: init EDP limit: 2065 MHz
[    0.581889] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    0.582333] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    0.582593] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[    0.582854] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.584502] bounce pool size: 64 pages
[    0.586256] NFS: Registering the id_resolver key type
[    0.586307] Key type id_resolver registered
[    0.586329] Key type id_legacy registered
[    0.586361] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.586992] NTFS driver 2.1.30 [Flags: R/O].
[    0.587332] fuse init (API version 7.22)
[    0.587727] msgmni has been set to 1461
[    0.590100] io scheduler noop registered (default)
[    0.590537] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[    0.590632] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[    0.590722] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[    1.296334] PCIE: port 0: link down, retrying
[    1.698530] PCIE: port 0: link down, retrying
[    2.100721] PCIE: port 0: link down, retrying
[    2.302814] PCIE: port 0: link down, ignoring
[    2.316996] PCI host bridge to bus 0000:00
[    2.317025] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[    2.317054] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[    2.317106] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    2.317135] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    2.317547] PCI: bus0: Fast back to back transfers disabled
[    2.317576] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.320153] PCI: bus1: Fast back to back transfers disabled
[    2.320498] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    2.320528] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    2.320779] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[    2.320813] pcieport 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    2.320845] pci 0000:01:00.0: BAR 0: assigned [mem 0x32100000-0x3211ffff]
[    2.320879] pci 0000:01:00.0: BAR 3: assigned [mem 0x32120000-0x32123fff]
[    2.320911] pci 0000:01:00.0: BAR 2: assigned [io  0x1000-0x101f]
[    2.320942] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[    2.320967] pcieport 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    2.320995] pcieport 0000:00:00.0:   bridge window [mem 0x32100000-0x321fffff]
[    2.321037] PCIE: No Link speed change happened
[    2.321487] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[    2.321596] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[    2.322525] tsec tsec: initialized
[    2.324017] isp isp.0: initialized
[    2.325023] isp isp.1: initialized
[    2.326656] falcon vic03.0: initialized
[    2.327867] falcon msenc: initialized
[    2.329724] tegradc tegradc.0: probed
[    2.329969] tegradc tegradc.0: parse cmd options for tegrafb0: 640x480-16@60
[    2.330009] tegradc tegradc.0: switching framebuffer to 640x480
[    2.330035] tegradc tegradc.0: Calculated sync href=0 vref=1
[    2.330063] tegradc tegradc.0: using mode 640x480 pclk=25175000 href=0 vref=1
[    2.364036] tegradc tegradc.0: nominal-pclk:25175000 parent:25125000 div:1.0 pclk:25125000 24923250~27440750
[    2.381543] tegradc tegradc.0: fb registered
[    2.382290] gpio wake4 for gpio=111
[    2.383206] tegradc tegradc.1: probed
[    2.384320] tegradc tegradc.1: use default mode for tegrafb1: 1920x1080-16@60
[    2.384375] tegradc tegradc.1: switching framebuffer to 1920x1080
[    2.384405] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[    2.385401] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[    2.387014] tegradc tegradc.1: switching framebuffer to 1920x1080
[    2.387024] tegradc tegradc.1: using mode 1920x1080 pclk=148500000 href=1 vref=1
[    2.389429] tegradc tegradc.1: nominal-pclk:148500000 parent:594000000 div:4.0 pclk:148500000 147015000~161865000
[    2.389500] tegra_dc_hdmi_enable: HDMI clock already configured to target frequency, skipping clk setup.
[    2.400929] Console: switching to colour frame buffer device 240x67
[    2.411992] tegradc tegradc.1: fb registered
[    2.412095] hdmi_state_machine_worker (tid edb875c0): state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    2.412208] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    2.415563] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[    2.416315] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[    2.418597] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[    2.453628] hdmi_state_machine_worker (tid edb875c0): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    2.453634] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    2.514548] hdmi_state_machine_worker (tid edb875c0): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    2.768989] panel size 47 by 29
[    4.560145] console [ttyS0] enabled
[    4.560191] tegradc tegradc.1: switching framebuffer to 1024x768
[    4.560202] tegradc tegradc.1: using mode 1024x768 pclk=65002000 href=1 vref=1
[    4.560626] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[    4.560906] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[    4.561204] serial-tegra.3: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[    4.563424] tegradc tegradc.1: nominal-pclk:65002000 parent:390000000 div:6.0 pclk:65000000 64351980~70852180
[    4.564643] tegradc tegradc.1: hdmi: can't set audio to 44100 at 65002000 pix_clock
[    4.564831] tegradc tegradc.1: switching framebuffer to 1024x768
[    4.564841] tegradc tegradc.1: using mode 1024x768 pclk=65002000 href=1 vref=1
[    4.567097] loop: module loaded
[    4.567251] nct1008_nct72 4-004c: success in enabling rail vdd_nct72
[    4.567521] tegradc tegradc.1: nominal-pclk:65002000 parent:390000000 div:6.0 pclk:65000000 64351980~70852180
[    4.571046] gpio wake35 for gpio=70
[    4.571138] nct1008_nct72 4-004c: nct1008_probe: initialized
[    4.571765] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[    4.572814] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[    4.573629] tegradc tegradc.1: switching framebuffer to 1024x768
[    4.573639] tegradc tegradc.1: using mode 1024x768 pclk=65002000 href=1 vref=1
[    4.574479] tegra_profiler: Branch: Dev
[    4.574482] tegra_profiler: Version: 1.103
[    4.574486] tegra_profiler: Samples version: 34
[    4.574488] tegra_profiler: IO version: 18
[    4.574494] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[    4.574658] tegra_profiler: auth: init
[    4.574960] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[    4.576023] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[    4.576035] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[    4.578131] scsi0 : tegra-sata
[    4.578373] tegradc tegradc.1: nominal-pclk:65002000 parent:390000000 div:6.0 pclk:65000000 64351980~70852180
[    4.578572] scsi1 : tegra-sata
[    4.578771] ata1: SATA max UDMA/133 irq 55
[    4.578775] ata2: DUMMY
[    4.580896] gpio wake34 for gpio=82
[    4.583464] tun: Universal TUN/TAP device driver, 1.6
[    4.583468] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.583636] CAN device driver interface
[    4.583672] Intel(R) Gigabit Ethernet Network Driver - version 5.3.5.4
[    4.583676] Copyright (c) 2007-2015 Intel Corporation.
[    4.584163] tegradc tegradc.1: using mode 1024x768 pclk=65002000 href=1 vref=1
[    4.598288] tegradc tegradc.1: nominal-pclk:65002000 parent:390000000 div:6.0 pclk:65000000 64351980~70852180
[    4.625582] igb 0000:01:00.0: added PHC on eth0
[    4.625589] igb 0000:01:00.0: Intel(R) Gigabit Ethernet Network Connection
[    4.625596] igb 0000:01:00.0: eth0: (PCIe:2.5GT/s:Width x1)
[    4.625603] igb 0000:01:00.0 eth0: MAC: 00:14:2d:2c:d4:25
[    4.625620] igb 0000:01:00.0: eth0: PBA No: Unknown
[    4.625644] igb 0000:01:00.0: LRO is disabled
[    4.625652] igb 0000:01:00.0: Using MSI-X interrupts. 1 rx queue(s), 1 tx queue(s)
[    4.625770] usbcore: registered new interface driver asix
[    4.625820] usbcore: registered new interface driver ax88179_178a
[    4.625860] usbcore: registered new interface driver cdc_ether
[    4.625898] usbcore: registered new interface driver cdc_subset
[    4.625930] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.626159] ehci-pci: EHCI PCI platform driver
[    4.626436] tegra_xusb_read_usb_calib: usb_calib0 = 0x02858389
[    4.626861] usbcore: registered new interface driver usb-storage
[    4.626973] usbcore: registered new interface driver usbserial
[    4.627010] usbcore: registered new interface driver usbserial_generic
[    4.627042] usbserial: USB Serial support registered for generic
[    4.627106] usbcore: registered new interface driver pl2303
[    4.627139] usbserial: USB Serial support registered for pl2303
[    4.627219] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[    4.627356] tegra USB phy - inst[0] platform info:
[    4.627359] port_otg: yes
[    4.627362] has_hostpc: yes
[    4.627365] phy_interface: USB_PHY_INTF_UTMI
[    4.627368] op_mode: TEGRA_USB_OPMODE_DEVICE
[    4.627370] qc2_voltage: 0
[    4.627373] vbus_pmu_irq: 0
[    4.627375] vbus_gpio: -1
[    4.627378] charging: disabled
[    4.627381] remote_wakeup: disabled
[    4.632736] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[    4.682355] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[    4.682363] as3722-rtc as3722-rtc.1: RTC interrupt 449
[    4.782268] rtc-ds1307 0-0068: oscillator failed, set time!
[    4.782442] rtc-ds1307 0-0068: rtc core: registered m41t0 as rtc1
[    4.782882] tegra_rtc tegra_rtc: rtc core: registered tegra_rtc as rtc2
[    4.782892] Wake16 for irq=34
[    4.782912] tegra_rtc tegra_rtc: Tegra internal Real Time Clock
[    4.782987] i2c /dev entries driver
[    4.783118] otg state changed: SUSPEND --> HOST
[    4.783330] tegra USB phy - inst[0] platform info:
[    4.783333] port_otg: yes
[    4.783336] has_hostpc: yes
[    4.783339] phy_interface: USB_PHY_INTF_UTMI
[    4.783342] op_mode: TEGRA_USB_OPMODE_HOST
[    4.783344] qc2_voltage: 0
[    4.783346] vbus_gpio: -1
[    4.783349] hot_plug: disabled
[    4.783352] remote_wakeup: enabled
[    4.786893] nvavp nvavp: allocated IOVA at 8ff00000 for AVP os
[    4.787618] tegra_dtv_probe: probing dtv.
[    4.788033] setup_stream: bufsize = 4096, bufnum = 4
[    4.788034] usbcore: registered new interface driver uvcvideo
[    4.788037] USB Video Class driver (1.1.1)
[    4.788505] zram: Created 1 device(s) ...
[    4.789250] tegra_wdt tegra_wdt.0: last reset is due to software reset
[    4.789398] WDT heartbeat enabled on probe
[    4.789401] tegra_wdt_probe done
[    4.789744] sdhci: Secure Digital Host Controller Interface driver
[    4.789746] sdhci: Copyright(c) Pierre Ossman
[    4.789749] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.790111] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[    4.790268] sdhci-tegra sdhci-tegra.3: Speedo value 2292
[    4.790277] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[    4.883127] ata1: SATA link down (SStatus 0 SControl 300)
[    5.383282] handle_check_edid_l: audio_switch 1
[    5.389662] Display connected, hpd_switch 1
[    5.395648] handle_check_edid_l: setting audio and infoframes
[    5.403230] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[    5.414268] hdmi_state_machine_worker (tid edb875c0): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[    5.425362] mmc0: no vqmmc regulator found
[    5.431457] mmc0: no vmmc regulator found
[    5.437408] mmc0: Invalid maximum block size, assuming 512 bytes
[    5.445396] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found
[    5.479113] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    5.491344] sdhci-tegra sdhci-tegra.0: Speedo value 2292
[    5.498925] sdhci-tegra sdhci-tegra.0: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[    5.510629] mmc1: no vqmmc regulator found
[    5.516889] mmc1: no vmmc regulator found
[    5.523000] mmc1: Invalid maximum block size, assuming 512 bytes
[    5.531205] sysedp_create_consumer: unable to create sdhci-tegra.0, no consumer_data for sdhci-tegra.0 found
[    5.565107] mmc1: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA
[    5.577809] sdhci-tegra sdhci-tegra.2: Speedo value 2292
[    5.585416] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1150
[    5.597346] mmc2: no vqmmc regulator found
[    5.603677] mmc2: no vmmc regulator found
[    5.609904] mmc2: Invalid maximum block size, assuming 512 bytes
[    5.618156] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found
[    5.652107] mmc2: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[    5.663946] mmc0: BKOPS_EN bit is not set
[    5.670385] gpio wake56 for gpio=170
[    5.673052] mmc0: new high speed DDR MMC card at address 0001
[    5.673280] mmcblk mmc0:0001: Card claimed for testing.
[    5.691988] mmcblk0: mmc0:0001 016G30 14.6 GiB
[    5.699100] mmcblk0boot0: mmc0:0001 016G30 partition 1 4.00 MiB
[    5.700814] tegra-se tegra12-se: tegra_se_probe: complete
[    5.701010] hidraw: raw HID events driver (C) Jiri Kosina
[    5.701157] usbcore: registered new interface driver usbhid
[    5.701160] usbhid: USB HID core driver
[    5.701620] tegra-hier-ictlr tegra-hier-ictlr: probed
[    5.744550] mmcblk0boot1: mmc0:0001 016G30 partition 2 4.00 MiB
[    5.752994] mmcblk0rpmb: mmc0:0001 016G30 partition 3 4.00 MiB
[    5.762542]  mmcblk0: p1 p2
[    5.769998]  mmcblk0boot1: unknown partition table
[    5.778734]  mmcblk0boot0: unknown partition table
[    5.789777] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[    5.798106] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 1
[    5.808179] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[    5.822114] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[    5.830441] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    5.839557] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.849086] usb usb1: Product: Tegra EHCI Host Controller
[    5.856467] mmc1: host does not support reading read-only switch. assuming write-enable.
[    5.859373] sdhci-tegra sdhci-tegra.0: Found T2T coeffs data
[    5.859384] sdhci-tegra sdhci-tegra.0: 81MHz tap hole coeffs found
[    5.883526] usb usb1: Manufacturer: Linux 3.10.40-2.7.4+ge963625 ehci_hcd
[    5.892599] usb usb1: SerialNumber: tegra-ehci.0
[    5.899967] hub 1-0:1.0: USB hub found
[    5.905956] hub 1-0:1.0: 1 port detected
[    6.147756] usbcore: registered new interface driver snd-usb-audio
[    6.157149] tegra_offload_platform probe successfull.
[    6.164434] succefully registered offload opstegra30_avp_audio_platform_probe successful.
[    6.175737] sgtl5000 4-000a: sgtl5000 revision 0x11
[    6.185349] 4-000a: 1200 mV normal
[    6.191234] sgtl5000 4-000a: Using internal LDO instead of VDDD
[    6.203351] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0:  sgtl5000 <-> tegra30-i2s.2 mapping ok
[    6.215900] usb 1-1: new low-speed USB device number 2 using tegra-ehci
[    6.225123] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0:  dit-hifi <-> tegra30-spdif mapping ok
[    6.239263] oprofile: using timer interrupt.
[    6.245892] GACT probability NOT on
[    6.251610] Mirror/redirect action on
[    6.257466] u32 classifier
[    6.262312]     Actions configured
[    6.267858] Netfilter messages via NETLINK v0.30.
[    6.274756] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    6.283417] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    6.292542] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    6.300820] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.308414] arp_tables: (C) 2002 David S. Miller
[    6.315177] TCP: cubic registered
[    6.320772] NET: Registered protocol family 10
[    6.328272] mip6: Mobile IPv6
[    6.333364] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    6.341535] NET: Registered protocol family 17
[    6.348171] NET: Registered protocol family 15
[    6.354701] can: controller area network core (rev 20120528 abi 9)
[    6.363091] NET: Registered protocol family 29
[    6.369614] can: raw protocol (rev 20120528)
[    6.376017] can: broadcast manager protocol (rev 20120528 t)
[    6.383818] can: netlink gateway (rev 20130117) max_hops=1
[    6.391516] NET: Registered protocol family 35
[    6.398170] 8021q: 802.1Q VLAN Support v1.8
[    6.399084] **********Auto tuning windows*************
[    6.399088] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.399095] win[0]: 0(0) - 91(1)
[    6.399099] win[1]: 105(0) - 255(1)
[    6.399102] ***************************************
[    6.399129] ********tuning windows after inserting holes*****
[    6.399132] WIN_ATTR legend: 0-BOUN_ST, 1-BOUN_END, 2-HOLE
[    6.399136] win[0]:-107(0) - 91(1)
[    6.399140] win[1]:105(0) - 161(2)
[    6.399144] win[2]:163(2) - 255(1)
[    6.399147] ***********************************************
[    6.399152] **********Tuning values*********
[    6.399155] **estimated values**
[    6.399161] T2T_Vmax 58, T2T_Vmin 79, 1'st_hole_Vmax 162, UI_Vmax 212
[    6.399165] **Calculated values**
[    6.399169] T2T_Vmax 58, 1'st_hole_Vmax 162, UI_Vmax 212
[    6.399174] T2T_Vmin 90, 1'st_hole_Vmin 103, UI_Vmin 137
[    6.399177] ***********************************
[    6.399182] ***********final tuning windows**********
[    6.399186] win[0]: -57 - 47
[    6.399189] win[1]: 122 - 91
[    6.399193] win[2]: 181 - 153
[    6.399196] ********************************
[    6.399201] best tap win - (-57-47), best tap value 0 prev_best_tap 0
[    6.399213] sdhci-tegra sdhci-tegra.0: sdhci_tegra_verify_best_tap: tuning freq 81600000hz, best tap 0
[    6.401245] mmc1: new ultra high speed SDR50 SDHC card at address 0001
[    6.401477] mmcblk mmc1:0001: Card claimed for testing.
[    6.402249] usb 1-1: New USB device found, idVendor=413c, idProduct=2003
[    6.402257] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.402264] usb 1-1: Product: Dell USB Keyboard
[    6.402270] usb 1-1: Manufacturer: Dell
[    6.611627] mmcblk1: mmc1:0001 SD8GB 7.32 GiB
[    6.611780] NET: Registered protocol family 37
[    6.611810] Key type dns_resolver registered
[    6.611816] NET: Registered protocol family 41
[    6.618190] input: Dell Dell USB Keyboard as /devices/platform/tegra-ehci.0/usb1/1-1/1-1:1.0/input/input0
[    6.618609] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-tegra-ehci.0-1/input0
[    6.664268]  mmcblk1: p1
[    6.668575] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    6.702576] Registering SWP/SWPB emulation handler
[    6.709278] last reset is due to software reset
[    6.709278]
[    6.719019] Disabling clocks left on by bootloader:
[    6.725758]    audio_2x
[    6.730192]    audio
[    6.734216]    audio4
[    6.738295]    audio3
[    6.742345]    audio2
[    6.746365]    audio1
[    6.750351]    audio0
[    6.754406]    hdmi_audio
[    6.758722]    entropy
[    6.762763]    dsi2-fixed
[    6.767033]    dsi1-fixed
[    6.771284]    mipi-cal-fixed
[    6.775887]    nor
[    6.779523]    trace
[    6.783312]    sdmmc3_ddr
[    6.787519]    sdmmc1_ddr
[    6.791747]    cclk_lp
[    6.795649]    pll_x_out0
[    6.799775]    pll_u_12M
[    6.803801]    pll_m_out1
[    6.808015] tegra_dvfs: vdd_cpu connected to regulator
[    6.814713] tegra_dvfs: vdd_core connected to regulator
[    6.821499] tegra_dvfs: vdd_gpu connected to regulator
[    6.829540] cpu_cold cooling device is registered
[    6.835902] cpu_hot cooling device is registered
[    6.836004] Tegra CPU DFLL is initialized with use_dfll = 1
[    6.836061] CPU rate: 696 MHz
[    7.007669] tegra dvfs: tegra sysfs cap interface is initialized
[    7.015104] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[    7.023479] tegra_actmon.emc: Completed initialization (0)
[    7.030476] tegra_actmon.avp: Completed initialization (0)
[    7.037352] tegra_mon.cpu_emc: Completed initialization (0)
[    7.047238] VCC_USBH(2A|2C|2D|3|4): incomplete constraints, leaving on
[    7.055055] +V1.8_VPP_FUSE: incomplete constraints, leaving on
[    7.062246] as3722-ldo7: incomplete constraints, leaving on
[    7.069122] VDDIO_SDMMC3: incomplete constraints, leaving on
[    7.076138] as3722-ldo5: incomplete constraints, leaving on
[    7.083083] as3722-sd3: incomplete constraints, leaving on
[    7.089913] +V3.3_MXM: incomplete constraints, leaving on
[    7.096608] regulator-dummy: incomplete constraints, leaving on
[    7.104497] file system registered
[    7.109994] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    7.118131] android_usb gadget: Number of LUNs=1
[    7.123972]  lun0: LUN: removable file: (no medium)
[    7.130420] android_maxim14675_set_voltage: max_voltage (vbus) = 5000
[    7.138104] android_usb gadget: android_usb ready
[    7.144034] tegra-udc: bind to driver android_usb
[    7.150213] gpio wake14 for gpio=235
[    7.155086] gpio-keys gpio-keys.3: Failed to request GPIO 117, error -16
[    7.163107] gpio-keys: probe of gpio-keys.3 failed with error -16
[    7.170932] as3722-rtc as3722-rtc.1: setting system clock to 2000-01-01 00:01:21 UTC (946684881)
[    7.181720] ALSA device list:
[    7.185837]   #0: Toradex Apalis TK1 SGTL5000
[    7.191410]   #1: HDA NVIDIA Tegra at 0x70038000 irq 113
[    7.199476] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    7.208901] List of all partitions:
[    7.213711] b300        15388672 mmcblk0  driver: mmcblk
[    7.220392]   b301           16384 mmcblk0p1 0001068f-01
[    7.227092]   b302        15339520 mmcblk0p2 0001068f-02
[    7.233802] b330            4096 mmcblk0rpmb  (driver?)
[    7.240365] b320            4096 mmcblk0boot1  (driver?)
[    7.247076] b310            4096 mmcblk0boot0  (driver?)
[    7.253787] b340         7675904 mmcblk1  driver: mmcblk
[    7.260544]   b341         7673856 mmcblk1p1 a6202af7-01
[    7.267254] No filesystem could mount root, tried:  ext3
[    7.274102] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
[    7.283975] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-2.7.4+ge963625 #1
[    7.292770] [<c0015290>] (unwind_backtrace+0x0/0x120) from [<c0011e78>] (show_stack+0x18/0x1c)
[    7.302886] [<c0011e78>] (show_stack+0x18/0x1c) from [<c07214e0>] (panic+0x8c/0x1d8)
[    7.312153] [<c07214e0>] (panic+0x8c/0x1d8) from [<c09f3fb8>] (mount_block_root+0x1b0/0x210)
[    7.322134] [<c09f3fb8>] (mount_block_root+0x1b0/0x210) from [<c09f40d0>] (mount_root+0xb8/0x104)
[    7.332569] [<c09f40d0>] (mount_root+0xb8/0x104) from [<c09f4260>] (prepare_namespace+0x144/0x184)
[    7.343110] [<c09f4260>] (prepare_namespace+0x144/0x184) from [<c09f3c20>] (kernel_init_freeable+0x15c/0x1bc)
[    7.354631] [<c09f3c20>] (kernel_init_freeable+0x15c/0x1bc) from [<c0719d54>] (kernel_init+0x10/0xe8)
[    7.365476] [<c0719d54>] (kernel_init+0x10/0xe8) from [<c000e4b8>] (ret_from_fork+0x14/0x20)
[    7.375536] CPU2: stopping
[    7.379894] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.40-2.7.4+ge963625 #1
[    7.388888] [<c0015290>] (unwind_backtrace+0x0/0x120) from [<c0011e78>] (show_stack+0x18/0x1c)
[    7.399229] [<c0011e78>] (show_stack+0x18/0x1c) from [<c001431c>] (handle_IPI+0xdc/0x1a4)
[    7.409147] [<c001431c>] (handle_IPI+0xdc/0x1a4) from [<c000856c>] (gic_handle_irq+0xcc/0x140)
[    7.419507] [<c000856c>] (gic_handle_irq+0xcc/0x140) from [<c000e000>] (__irq_svc+0x40/0x70)
[    7.429694] Exception stack(0xee28bf28 to 0xee28bf70)
[    7.436493] bf20:                   00000000 000f4240 0001942c 00000000 00000000 c1c427b0
[    7.446450] bf40: b003b839 00000001 b003b5f2 00000001 c1c403b0 00000000 062acfdb ee28bf70
[    7.456414] bf60: c005f130 c003933c 20000113 ffffffff
[    7.463261] [<c000e000>] (__irq_svc+0x40/0x70) from [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78)
[    7.474765] [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78) from [<c053cc48>] (cpuidle_enter_state+0x40/0xdc)
[    7.487165] [<c053cc48>] (cpuidle_enter_state+0x40/0xdc) from [<c053cf14>] (cpuidle_idle_call+0x230/0x254)
[    7.498712] [<c053cf14>] (cpuidle_idle_call+0x230/0x254) from [<c000f1ec>] (arch_cpu_idle+0x10/0x40)
[    7.509735] [<c000f1ec>] (arch_cpu_idle+0x10/0x40) from [<c009ec94>] (cpu_startup_entry+0x1ac/0x200)
[    7.520773] [<c009ec94>] (cpu_startup_entry+0x1ac/0x200) from [<8071bd04>] (0x8071bd04)
[    7.530692] CPU1: stopping
[    7.535646] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.40-2.7.4+ge963625 #1
[    7.545247] [<c0015290>] (unwind_backtrace+0x0/0x120) from [<c0011e78>] (show_stack+0x18/0x1c)
[    7.556182] [<c0011e78>] (show_stack+0x18/0x1c) from [<c001431c>] (handle_IPI+0xdc/0x1a4)
[    7.566705] [<c001431c>] (handle_IPI+0xdc/0x1a4) from [<c000856c>] (gic_handle_irq+0xcc/0x140)
[    7.577672] [<c000856c>] (gic_handle_irq+0xcc/0x140) from [<c000e000>] (__irq_svc+0x40/0x70)
[    7.588469] Exception stack(0xee289f28 to 0xee289f70)
[    7.595862] 9f20:                   00000000 000f4240 0000bf6b 00000000 00000000 c1c397b0
[    7.606397] 9f40: b342c786 00000001 b342c5e6 00000001 c1c373b0 00000000 02ebb804 ee289f70
[    7.616944] 9f60: c005f130 c003933c 20000113 ffffffff
[    7.624376] [<c000e000>] (__irq_svc+0x40/0x70) from [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78)
[    7.636449] [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78) from [<c053cc48>] (cpuidle_enter_state+0x40/0xdc)
[    7.649409] [<c053cc48>] (cpuidle_enter_state+0x40/0xdc) from [<c053cf14>] (cpuidle_idle_call+0x230/0x254)
[    7.661527] [<c053cf14>] (cpuidle_idle_call+0x230/0x254) from [<c000f1ec>] (arch_cpu_idle+0x10/0x40)
[    7.673133] [<c000f1ec>] (arch_cpu_idle+0x10/0x40) from [<c009ec94>] (cpu_startup_entry+0x1ac/0x200)
[    7.684785] [<c009ec94>] (cpu_startup_entry+0x1ac/0x200) from [<8071bd04>] (0x8071bd04)
[    7.695316] CPU3: stopping
[    7.701960] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.10.40-2.7.4+ge963625 #1
[    7.713250] [<c0015290>] (unwind_backtrace+0x0/0x120) from [<c0011e78>] (show_stack+0x18/0x1c)
[    7.725923] [<c0011e78>] (show_stack+0x18/0x1c) from [<c001431c>] (handle_IPI+0xdc/0x1a4)
[    7.738272] [<c001431c>] (handle_IPI+0xdc/0x1a4) from [<c000856c>] (gic_handle_irq+0xcc/0x140)
[    7.750975] [<c000856c>] (gic_handle_irq+0xcc/0x140) from [<c000e000>] (__irq_svc+0x40/0x70)
[    7.763490] Exception stack(0xee28df28 to 0xee28df70)
[    7.772668] df20:                   00000000 000f4240 000243c0 00000000 00000000 c1c4b7b0
[    7.784965] df40: ad55dd72 00000001 ad55db7e 00000001 c1c493b0 00000000 08d8a512 ee28df70
[    7.797191] df60: c005f130 c003933c 20000113 ffffffff
[    7.806249] [<c000e000>] (__irq_svc+0x40/0x70) from [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78)
[    7.820080] [<c003933c>] (tegra_idle_enter_clock_gating+0x64/0x78) from [<c053cc48>] (cpuidle_enter_state+0x40/0xdc)
[    7.834787] [<c053cc48>] (cpuidle_enter_state+0x40/0xdc) from [<c053cf14>] (cpuidle_idle_call+0x230/0x254)
[    7.848611] [<c053cf14>] (cpuidle_idle_call+0x230/0x254) from [<c000f1ec>] (arch_cpu_idle+0x10/0x40)
[    7.861910] [<c000f1ec>] (arch_cpu_idle+0x10/0x40) from [<c009ec94>] (cpu_startup_entry+0x1ac/0x200)
[    7.875193] [<c009ec94>] (cpu_startup_entry+0x1ac/0x200) from [<8071bd04>] (0x8071bd04)
[   36.078071] ------------[ cut here ]------------
[   36.088572] WARNING: at /workdir/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/kernel/watchdog.c:270 watchdog_timer_fn+0x144/0x268()
[   36.113052] Watchdog detected hard LOCKUP on cpu 1
[   36.117733] Modules linked in:
[   36.133186] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-2.7.4+ge963625 #1
[   36.146190] [<c0015290>] (unwind_backtrace+0x0/0x120) from [<c0011e78>] (show_stack+0x18/0x1c)
[   36.160606] [<c0011e78>] (show_stack+0x18/0x1c) from [<c005841c>] (warn_slowpath_common+0x54/0x74)
[   36.175772] [<c005841c>] (warn_slowpath_common+0x54/0x74) from [<c0058470>] (warn_slowpath_fmt+0x34/0x44)
[   36.191423] [<c0058470>] (warn_slowpath_fmt+0x34/0x44) from [<c00bd29c>] (watchdog_timer_fn+0x144/0x268)
[   36.207059] [<c00bd29c>] (watchdog_timer_fn+0x144/0x268) from [<c007f834>] (__run_hrtimer+0x174/0x270)
[   36.222107] [<c007f834>] (__run_hrtimer+0x174/0x270) from [<c0080228>] (hrtimer_interrupt+0x170/0x28c)
[   36.237595] [<c0080228>] (hrtimer_interrupt+0x170/0x28c) from [<c05668d0>] (arch_timer_handler_phys+0x30/0x38)
[   36.253823] [<c05668d0>] (arch_timer_handler_phys+0x30/0x38) from [<c00c0f0c>] (handle_percpu_devid_irq+0xe4/0x190)
[   36.270442] [<c00c0f0c>] (handle_percpu_devid_irq+0xe4/0x190) from [<c00bd6f0>] (generic_handle_irq+0x28/0x38)
[   36.286627] [<c00bd6f0>] (generic_handle_irq+0x28/0x38) from [<c000ed48>] (handle_IRQ+0x80/0x98)
[   36.301555] [<c000ed48>] (handle_IRQ+0x80/0x98) from [<c00084ec>] (gic_handle_irq+0x4c/0x140)
[   36.316524] [<c00084ec>] (gic_handle_irq+0x4c/0x140) from [<c000e000>] (__irq_svc+0x40/0x70)
[   36.331206] Exception stack(0xee0d9e60 to 0xee0d9ea8)
[   36.342241] 9e60: 00000000 00000000 ff691f00 c0566fc0 1b8e6345 00002edf 00006dc4 00006e28
[   36.356282] 9e80: 00000019 c0b0421c 3ffffcc8 c08b240c 00000000 ee0d9ea8 c02bd54c c02bd594
[   36.370613] 9ea0: 60000113 ffffffff
[   36.380155] [<c000e000>] (__irq_svc+0x40/0x70) from [<c02bd594>] (__timer_delay+0x30/0x50)
[   36.394207] [<c02bd594>] (__timer_delay+0x30/0x50) from [<c0721600>] (panic+0x1ac/0x1d8)
[   36.408272] [<c0721600>] (panic+0x1ac/0x1d8) from [<c09f3fb8>] (mount_block_root+0x1b0/0x210)
[   36.422908] [<c09f3fb8>] (mount_block_root+0x1b0/0x210) from [<c09f40d0>] (mount_root+0xb8/0x104)
[   36.437955] [<c09f40d0>] (mount_root+0xb8/0x104) from [<c09f4260>] (prepare_namespace+0x144/0x184)
[   36.452860] [<c09f4260>] (prepare_namespace+0x144/0x184) from [<c09f3c20>] (kernel_init_freeable+0x15c/0x1bc)
[   36.468854] [<c09f3c20>] (kernel_init_freeable+0x15c/0x1bc) from [<c0719d54>] (kernel_init+0x10/0xe8)
[   36.484083] [<c0719d54>] (kernel_init+0x10/0xe8) from [<c000e4b8>] (ret_from_fork+0x14/0x20)
[   36.498598] ---[ end trace 62868ee7979517b8 ]---
Any help is greatly appreciated.
Another data item: SD card formatted as Fat32 under Windows 10. Is this an issue?
Hi
Please have a look at this community post.
It is highly unlikely that this has anything to do with an SD card formated under Windows 10.
Max
Thanks for the quick reply. That took care of the issue. Do you know who might be able to update the instructions on the getting started web page so that other folks won’t run into this?
The instructions have been updated. Thank you very much for the feedback.
Best regards.
