Boot AM69 on power-up
What jumpers do I configure on the developer board to configure the AM69 to boot on power-up?
Hello! Thank you for your question.
Based on the available documentation for the SMARC Development Board, there is no specific information about jumpers for configuring the AM69 module to boot on power-up. The documentation covers jumpers for interfaces like CAN and other hardware configurations, but does not describe any boot configuration jumpers for the AM69.
For official resources, you can refer to the following documentation:
If your goal is to ensure the module boots automatically when powered on, typically the default behavior of the development board and module is to boot as soon as power is applied, provided the module is correctly seated and the board is powered via the recommended method.
If you have adjusted any boot configuration options previously or if your board/module is not booting on power-up as expected, please provide more details so I can assist further.
Unfortunately, the Aquila development board is not designed to automatically power up the Aquila module upon applying main power via J17.
However, on a custom carrier board, VCC is the only power supply required for the module to become operational. Once VCC is present and within specification, the module will automatically power up and begin normal operation.
