How do you implement the blur effect shaders as demonstrated in this article? The Windows CE reference for the shaders state that the OEM must provide header files for the shaders as part of the SDK. Searching through the SDK I can not find the required header files. Is there a code example of how the shaders were implemented in the demonstration.
Have you installed this CAB?
