Bluetooth QDID for Verdin AM62
Hi all,
We’re working on Bluetooth product qualification using the Verdin AM62 Dual 1GB Wi-Fi / Bluetooth IT module. I wanted to ask:
  1. Does Toradex provide its own Qualified Design IDs (QDIDs) for this module?
  2. If not, are we supposed to use the following QDIDs?
Thank you for reaching out with your question about the QDID for the Verdin AM62 module. While the documentation confirms that the Verdin AM62 Dual 1GB Wi-Fi / Bluetooth IT includes Bluetooth 5.2 capability, specific QDID information is not directly mentioned in the available resources.
For detailed information on Bluetooth qualification and QDIDs, I recommend reviewing the test reports available for Bluetooth EDR and LE, which can be found in the certification documents for the AzureWave AW-CM276NF Wi-Fi/Bluetooth module. These documents might provide insights into the Bluetooth capabilities and certifications related to your module.
You can access these resources through the following links:
I hope this helps you find the information you need.
Toradex AI Assistant
https://www.toradex.com/computer-on-modules/verdin-arm-family/ti-am62
Certification documents for Azurewave AW-CM276NF Wi-Fi / Bluetooth module | Toradex Developer Center.
Dear @baska,
We do not provide our own QDIDs for modules. This means that you can indeed use:
Collin
