I added a bluetooth dongle. IT is recognized using lsusb:
Bus 002 Device 003: ID 0a5c:21e8 Broadcom Corp. BCM20702A0 Bluetooth 4.0
I’ve started the bluetooth service: systemctl start bluetooth.service
When I run the following command I got error: connmanctl enable bluetooth
Error bluetooth: Method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
The bluetooth dongle is LM506 from your list. The OS is Boot2Qt 5.13.0
Any suggestion?
Matteo
Hi @matteo_s
Could you provide the software version ( uname -a ) of your module?
Thanks and best regards,
Linux b2qt-apalis-imx6 4.9.144-2.8.5+g5758a8e648a3 #1 SMP Tue Feb 26 09:02:14 UTC 2019 armv7l armv7l armv7l GNU/Linux
hi @matteo_s
Thanks for the information. We will look into this issue and come within this week to you.
Hi @matteo_s
Could you check if the backports are included in your boot2qt image or not. If not, you can add them as explained here and here?
Thanks and Best regards,
How can I check if the backports are included?
You need to check if the backports recipe mentioned in the link above is included in your b2qt image recipe. If you have a commercial qt license, then you should contact Qt for this issue.
