I’m trying to switch back from Linux to Windows CE firmware.
I’ll give you the script and terminal logs right away. What can be done?
Toradex NVFlash Update Script
Nvflash version 2.6 started
rcm version 0X20001
System Information:
chip name: t20
chip id: 0x20 major: 1 minor: 4
chip sku: 0x8
chip uid: 0x00000000000000000271118840007297
macrovision: disabled
hdcp: enabled
jtag: enabled
sbk burned: false
dk burned: false
boot device: nand
operating mode: 3
device config strap: 0
device config fuse: 4128
sdram config strap: 0
Sending generated BCT...333Mhz Done
downloading bootloader -- load address: 0x08300000 entry point: 0x08300000
sending file: loader.nb0
\ 467360/467360 bytes sent
loader.nb0 sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
MAC: TID=0x00142D, CID=********
HW: VerMaj=1, VerMin=2, Variant=0, ProdID=21
Updating BCT
Sending generated BCT...RamSize=512MB, isApalis=0, isIT=0, 333Mhz Done
setting device: 0 0
deleting device partitions
creating partition: BCT
creating partition: PT
creating partition: EBT
creating partition: EB2
creating partition: IM2
creating partition: BMP
creating partition: CE6
creating partition: ARG
creating partition: REG
creating partition: USR
sending file: EBOOT.NB0
\ 503272/503272 bytes sent
EBOOT.NB0 sent successfully
- 503272/503272 bytes sent
sending file: Splashscreen.bmz
- 4426/4426 bytes sent
Splashscreen.bmz sent successfully
sending file: NK_CE6.NB0
| 17555916/17555916 bytes sent
NK_CE6.NB0 sent successfully
Sending Sync...
Sync Successful
Terminal:
Toradex Flash Loader 2.6 for Tegra Built May 6 2019 17:38:39
DeviceUID: 0x00000000000000000271118840007297
Nand Boot Device
Micron M71M PS:4KB BS:256KB DS:0MB BCH16 ECC
Detecting Memory Size...
512MB RAM
AdjustingBCT: NAND, PageSize=4KB, BlockSize=256KB, RamSize=512MB, isApalis=0, isIT=0
Read BCT ConfigBlock
MAC: tid=0x00142D, cid=10682363
Read ARG ConfigBlock
WARNING: Missing PROD Entry
UpdateBCT
Defaulting ECC to: BCH16
+NandUtilFormatDev(1)
BlkDev: Factory Bad block: Chip0 Block=10,FCB=0x0
BlkDev: Factory Bad block: Chip0 Block=100,FCB=0x0
-NandUtilFormatDev()
PartId 2: LB[0 2] PB[0 6] IL1 LS[0 128]
Chip0 Block=10 bad
PartId 3: LB[2 1] PB[6 6] IL1 LS[128 64]
PartId 4: LB[3 2] PB[12 6] IL1 LS[192 128]
PartId 10: LB[5 2] PB[18 6] IL1 LS[320 128]
PartId 11: LB[7 16] PB[24 20] IL1 LS[448 1024]
PartId 5: LB[23 1] PB[44 5] IL1 LS[1472 64]
Chip0 Block=100 bad
PartId 7: LB[24 400] PB[49 417] IL1 LS[1536 25600]
PartId 8: LB[424 1] PB[466 6] IL1 LS[27136 64]
PartId 9: LB[425 12] PB[472 17] IL1 LS[27200 768]
Partition 13 - number of physical blocks = 3603
PartId 13: LB[437 5] PB[489 3603] IL1 LS[27968 230592]
Save Region Table copy 0 at CurrBlockNum 4095
Save Region Table copy 1 at CurrBlockNum 4094
Save Region Table copy 2 at CurrBlockNum 4093
Save Region Table copy 3 at CurrBlockNum 4092
Erase Partition part-id=3: Start=6,End=11
FtlLite: Factory Bad block: Chip0 Block=10,FCB=0x0
EraseAllBlocks: factory bad block @ chip=0,blk=10
Bad block in pba2lba ftlite map: chip=0, blk=10
Start Downloading EBT
End Downloading EBT
Start Downloading EB2
End Downloading EB2
Start Downloading BMP
End Downloading BMP
Start Downloading CE6
EraseAllBlocks: factory bad block @ chip=0,blk=100
Bad block in pba2lba ftlite map: chip=0, blk=100
End Downloading CE6
Syncing BCTs...
WriteAllBcts_Write 1,0
WriteAllBcts_Write 64,1
WriteAllBcts_Write 0,0
Syncing BCTs Successfully Completed
Wrote ConfigBlock MAC HW
Nv3pServer(): Exiting
Done
Toradex Bootloader 2.4 for Tegra Built Jan 7 2022 14:04:27
Press [SPACE] to enter Bootloader Menu
Colibri T20 512MB 1.2A Serial: **********
RAM: 512 MB, CarveOut: 64 MB
Bad block in pba2lba ftlite map: chip=0, blk=100 Loading IM1 image from flash...
Bad block in pba2lba ftlite map: chip=0, blk=100 Done(937ms)
Checking Image CRC...OK(48ms)
Decompressing IMAGE(17555884, 33594664) from 8201FD3C to 80016000...Done(378ms)
Jumping to image at 0x80016000...
