BLE connection issue on Colibri IMX6ULL
Hi, I have Colibri imx6ull SOM with Colibri Evaluation board and trying to use internal Wi-Fi/Bluetooth module to connect with board over BLE. I have connected two Unictron AA 222 antenas to Wi-Fi/Bluetooth module and using build Yocto dunfell-5.x.y image. I have faced with BLE connection issue, I tried to connect to board using nRFConnect utility on my mobile phone, but BLE connection constantly disconnects after few seconds. btmon utility shows the disconnect reason: Connection timeout.
Also I have checked this issue on pre-built Toradex images with 3.0.4 and 5.0.1 versions, but this images also have the same issue with my Yocto image. How can I resolve this issue?
Hi @askripko and Welcome to the Toradex Community!!!
Could you flash the latest 5.1 release and follow these instructions to do a Bluetooth connection and report the errors in text format?
Thanks and best regards,
@jaski.tx thank you for your answer. I have tested BLE connection on Toradex 5.1.0 release, it has the same issue.
> HCI Event: Disconnect Complete (0x05) plen 4        #35 [hci0] 123.892220
        Status: Success (0x00)
        Handle: 128
        Reason: Connection Timeout (0x08)
@ MGMT Event: Device Disconnected (0x000c) plen 8        {0x0001} [hci0] 123.892356
        LE Address: C8:F7:33:DB:5A:0F (Intel Corporate)
        Reason: Connection timeout (0x01)
But BLE works good (no disconnections occur) after I establish Bluetooth Classic connection as described in instruction above. But in my case I need only BLE connection.
Hi @askripko
Thanks for your Input.
What do you differently in your only BLE Connection case?
@jaski.tx In BLE connection case I enable advertising and low energy support, using btmgmt utility on the device. After that I trying to connect from Mobile Phone using nRFConnect utility and after few seconds it disconnects.
@jaski.tx I can share with you simple shell script that I use to enable BLE on the device.
Firstable you need to unblock bluetooth device by next rfkill command:
rfkill unblock bluetooth
After that you can runenable_ble.sh script and connect to device using nRF Connect utility on Mobile device or something like that. enable_ble.sh using btmgmt tool to setup Low Energy support on the device, but Toradex image doesn’t have this tool in default. I also can share this utility with you.
BLE tools
Hi @askripko
I tested this on my side with nRF connect on Galaxy J5 and i didn’t see any automatic disconnection. Are you using two antennas on your side? If yes, which ones?
Hi @jaski.tx. Yes, I am using two Unictron AA 222 antenas. I have this issue on three boards.
Thanks. Which mobile phone are you using?
Three out of how many boards? Did you install the same image on these devices?
Which carrier board are you using?
I have only three Colibri Evaluation V3.2B boards. Yes, I tested with the same image on these devices.
I have tested on different phones, Nokia 6.1 Plus, IPhone XR.
Hi @askripko
We tested also on Pocophone and we still don’t see any issue. We will continue to test with some other phones to reproduce the issue.
Hi @askripko
We also made Tests with some other phones as IPhone and we didn’t see any issues.
Could you share the dmesg.log when this disconnection happens?
Hi @jaski.tx
I don’t see any specific messages in dmesg log when the disconnection happens, the dmesg log doesn’t change during disconnection. I have connected the USB Bluetooth dongle and it works well with BLE connection, but I would like to use builtin Bluetooth/WiFi module. Can it be the specific issue with my modules?
Hi @askripko
I don’t think that your modules are damaged. Its more the whole setup. If you wish, you could file up a RMA and we can make the tests with one specific module on our side.
