We are trying to develop an application for BLE 5.0 and above.
Some Necessary info:
- Board - Colibri iMX6ULL 512MB WB IT
- Carrier - Aster
- OS Build with Yocto Project
- BlueZ Version - 5.64 (experimental and compat flag used in bluetooth.service)
We are currently developing for following features of BLE5 with nRF52 hardware.
- Extended advertisement
- Periodic advertisement
When I use bluetoothctl to scan for devices I cannot find the advertising device. Following are the list of commands in order.
$ bluetoothctl
[bluetooth]# power on
[bluetooth]# menu scan
[bluetooth]# transport le
[bluetooth]# back
[bluetooth]# scan on
Also, going through BlueZ documentation, we couldn’t find anything related to the following:
- Set or Get Scanning parameters(scan interval, scan window)
except the mgmt-api. However, we are not sure how to use the same.
Kindly give some insights regarding the same.
Nikhil
Hi @hexagun,
Please see the instructions given here on how you can enable and connect to a bluetooth device.
We have followed the steps, but are stuck with receiving BLE 5 advertisements.
bluetoothctl does not show BLE 5 advertisements. Similarly sniffing with btmon doesn’t show advertisements too.
If the hardware supports for BLE 5, why are we not able to view the advertisements?
Hi @hexagun ,
Just to have more clarity, “stuck with receiving BLE 5 advertisement” you mean your BLE 5 enabled device is not discoverable on Colibri iMX6ULL and vice-versa?
Yes, that is the case.
We have a Nordic NRF52 device sending BLE 5 extended advertisements. I looked at the received messages at HCI using btmon but couldn’t see the advertisements received report for the advertisements.
Hi @hexagun,
I don’t have Nordic NRF52 to test with but I tested with my mobile device supporting Bluetooth 5.0. I can see the advertisements on both end.
Here are the steps
root@colibri-imx6ull-06398948:~# connmanctl enable bluetooth
Error bluetooth: Already enabled
root@colibri-imx6ull-06398948:~# bluetoothctl
Agent registered
[CHG] Controller D0:C5:D3:33:CE:8A Pairable: yes
Discovery started
[CHG] Controller D0:C5:D3:33:CE:8A Discovering: yes
[NEW] Device 64:A2:F9:05:3C:3B OnePlus 6
[NEW] Device 90:61:AE:EF:CD:9B tdev-HP-ProBook-440-G4
[DEL] Device 64:A2:F9:05:3C:3B OnePlus 6
bluetooth]# discoverable on
Changing discoverable on succeeded
[CHG] Controller D0:C5:D3:33:CE:8A Discoverable: yes
More details here
Let me know if this solves your issue
