This is the postgresql_9.6.17.bb
recipe I tried building into my custom image which is based on torizon-core-docker
(dunfell-5.x.y)
SUMMARY = "PostgreSQL is a powerful, open source relational database system."
DESCRIPTION = "\
PostgreSQL is an advanced Object-Relational database management system \
(DBMS) that supports almost all SQL constructs (including \
transactions, subselects and user-defined types and functions). The \
postgresql package includes the client programs and libraries that \
you'll need to access a PostgreSQL DBMS server. These PostgreSQL \
client programs are programs that directly manipulate the internal \
structure of PostgreSQL databases on a PostgreSQL server. These client \
programs can be located on the same machine with the PostgreSQL \
server, or may be on a remote machine which accesses a PostgreSQL \
server over a network connection. This package contains the docs \
in HTML for the whole package, as well as command-line utilities for \
managing PostgreSQL databases on a PostgreSQL server. \
If you want to manipulate a PostgreSQL database on a local or remote \
PostgreSQL server, you need this package. You also need to install \
this package if you're installing the postgresql-server package. \
HOMEPAGE = "http://www.postgresql.com"
LICENSE = "BSD"
LIC_FILES_CHKSUM = "file://COPYRIGHT;md5=fc4ce21960f0c561460d750bc270d11f"
DEPENDS = "zlib readline tzcode-native"
ARM_INSTRUCTION_SET = "arm"
SRC_URI = "http://ftp.postgresql.org/pub/source/v${PV}/${BP}.tar.bz2 \
file://postgresql.init \
SRC_URI[md5sum] = "4a12dd9e2afe140a8d2d4366471b075f"
SRC_URI[sha256sum] = "f6e1e32d32545f97c066f3c19f4d58dfab1205c01252cf85c5c92294ace1a0c2"
inherit autotools useradd
USERADD_PACKAGES = "${PN}"
USERADD_PARAM_${PN} = "postgres"
EXTRA_OECONF += "--enable-thread-safety --disable-rpath \
--datadir=${datadir}/${BPN} \
--sysconfdir=${sysconfdir}/${BPN}/9.6/main \
do_install_append() {
# /etc/init.d
install -d ${D}${sysconfdir}/init.d
# copy postgresql.init to /etc/init.d/postgresql
install -m 0755 ${WORKDIR}/${BPN}.init ${D}${sysconfdir}/init.d/${BPN}
# /etc/postgresql/9.6/main
install -d -m 700 ${D}${sysconfdir}/${BPN}/9.6/main
# data directory - /var/lib/postgresql/9.6/main
install -d -m 700 ${D}${localstatedir}/lib/${BPN}/9.6/main
chown -R postgres:postgres ${D}${localstatedir}/lib/${BPN}/9.6/main
FILES_${PN} += "${localstatedir}/lib/${BPN}/9.6/main \
The recipe gets built successfully and the package is available in the final image as well.
The only problem is that it is not able to create a new directory /var/lib/postgresql/9.6/main
in the final rootfs of the image. This is verified after updating the final image in the toradex module using ostree as mentioned in OSTree Update From a Local TorizonCore Build.
Also note that the install command to create directory /etc/init.d
and /etc/postgresql/9.6/main
works fine as these directories are present in the updated rootfs.
