I am failing to install a new Linux image from an SD card onto my Colibri iMX7S 256MB V1.1B mounted on eval board V3.2B. I extracted a file named “Colibri-iMX7_LXDE-Image_2.8b2-20180612.tar.bz2” produced by bitbake onto an 8GB SD Card. When using the Easy Installer, inserting the SD card does not produce a local choice, only the usual choices from the internet. When allowing the boot to complete, the SD card shows up, mounted at /media/mccblk0p1, and looks like the extraction went well. Do I need any particular file structure? Interrupting the boot and running “run setupdate” results in an error message “** Unable to read file colibri_imx7/flash_blk.img **”. There is a file named “flash_blk.img” on the SD card, but under a directory named"colibri-imx7_bin", a couple levels down.
The Toradex Easy Installer (short Tezi) needs an image in the new Tezi format. The file ending is .tar and contains Tezi in its name (e.g. Colibri-iMX7_LXDE-Image-Tezi_2.7b4-20171004.tar).
Oops on last comment, found the file, moved it to the SD card, extracted contents, and Voila! Works great, thanks!
perfect. Thanks for the feedback.
