Hello Mansij,
Thank you for reaching out with your question. The error you’re encountering is due to a mismatch between the name of the binary file generated during the compilation step and the name expected during the installation step in your Yocto recipe.
In your nsgtk_1.0.0.bb
file, the do_compile
function compiles the nsgtk.c
file into a binary named hello_gtk
do_compile() {
${CC} -Wall ${LDFLAGS} nsgtk.c -o hello_gtk `pkg-config --cflags --libs gtk+-3.0`
However, in the do_install
function, you are trying to install a binary named nsgtk
do_install() {
install -d ${D}${bindir}
install -m 755 ${S}/nsgtk ${D}${bindir}/
To resolve this issue, you need to ensure that the binary name in the do_install
step matches the name of the compiled binary. You can do this by changing the do_install
function to:
do_install() {
install -m 755 ${S}/hello_gtk ${D}${bindir}/
This change should resolve the error by correctly referencing the compiled binary hello_gtk
during the installation step. After making this change, try running bitbake nsgtk
again.
I hope this helps! If you have any more questions, feel free to ask.
Toradex AI Assistant
What Linux OS do I need to use to create and use GTK application?.
