I follow steps to build Yocto Linux dunfell-5.x.y
I use docker with Ubuntu 18.04
docker run --name yocto-nobilis-5.x.y -it -v $PWD/yocto/output:/home/nobilis_developer/yocto/output yocto_ubuntu_18.04
nobilis_developer@8f9ea031c833:/$ cd ~/yocto/output/
cd oe-core/
repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
repo sync
. export
in the …/oe-core/build/conf/local.conf :
MACHINE ?= “apalis-imx6”
ACCEPT_FSL_EULA = “1”
bitbake -k tdx-reference-multimedia-image
and the result is error messages after the reconnection attempts
NOTE: Reconnecting to bitbake server...
NOTE: Retrying server connection (#1)... (Traceback (most recent call last):
File "/home/nobilis_developer/yocto/output/oe-core/layers/openembedded-core/bitbake/lib/bb/main.py", line 455, in setup_bitbake
server_connection = bb.server.process.connectProcessServer(sockname, featureset)
File "/home/nobilis_developer/yocto/output/oe-core/layers/openembedded-core/bitbake/lib/bb/server/process.py", line 505, in connectProcessServer
sock.connect(os.path.basename(sockname))
BlockingIOError: [Errno 11] Resource temporarily unavailable
yesterday and today result is the same
How to build Yocto dunfell-5.x.y ?
