I made an upgrade to LinuxImageV2.8 and tried to bitbake an toradex-demo-image (e.g. angstrom-qt5-x11-image). The build fails with Error:
ERROR: mobile-broadband-provider-info-1_20170310-r0 do_unpack: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-QdnUMdraTc"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/res/develop/oe-core/layers/openembedded-core/scripts:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot/usr/bin/crossscripts:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot-native/usr/sbin:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot-native/usr/bin:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot-native/sbin:/home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/recipe-sysroot-native/bin:/home/res/develop/oe-core/layers/openembedded-core/bitbake/bin:/home/res/develop/oe-core/build/tmp-glibc/hosttools"; export HOME="/home/res"; git -c core.fsyncobjectfiles=0 checkout -B master befcbbc9867e742ac16415660b0b7521218a530c failed with exit code 128, output:
fatal: reference is not a tree: befcbbc9867e742ac16415660b0b7521218a530c
ERROR: mobile-broadband-provider-info-1_20170310-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/res/develop/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/mobile-broadband-provider-info/1_20170310-r0/temp/log.do_unpack.7747
ERROR: Task (/home/res/develop/oe-core/build/../layers/openembedded-core/meta/recipes-connectivity/mobile-broadband-provider-info/mobile-broadband-provider-info_git.bb:do_unpack) failed with exit code '1'
The same happens with my own custom Image wich mainly based on toradex demo-image angstrom-qt5-x11-image.
Any hint, whats going wrong here?
