Hi, I did and rebuilt.Now it is successful.
I then built bitbake -k meta-toolchain-qt5 which was also successful
Now I started qt , added QT versions, compilers debuggers which was ok.
Then I added the kit and gave the Qt mkspec path as /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ as per the document but when I try to build the application in qt creator It says
Cannot Read /usr/local/oecore-x86_64/sysroots/armv7at2hf-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++/qmake.conf
Could not read qmake configuration file.
However when I checked the files it is very much there .
What could go wrong?
I completed building the image and sdk successfully. I also installed qtcreator , added device, compiler and kit. But when I deploy I get a error “error while loading shared libraries : libQt5Widgets.so.5: cannot open shared object file. no such file or directory. Application finishes with exit code 127”
I checked usr/lib on device but there are no qt5 libraries. Is the location of QT libraries correct?
Despite of creating the image using bitbake -k angstrom-qt5-x11-image… why should this happen.?
Pls advise how to proceed.?
