Recently I have been trying to add a custom binary, compiled using the :
aarch64-linux-gnu-gcc
crosscompiler, to mij custom rootfs built using bitbake. I’m trying to install the executable binary in the {bindir}. I get following error:
ERROR: meta-aedin-1.0-r0 do_package_qa: QA Issue: No GNU_HASH in the ELF binary
Online I’ve looked for two solutions either try to add the GNU hash to the compiler using -Wl,–hash-style=gnu or to add the INSANE_SKIP_${PN} += “ldflags” tot he bitbake layer file.
Both options remove the initial error however now the entire rootfs built fails to add any library. Does anybody have a simular issue/solution to this issue? Or how to add a prebuilt binary to bitbake ?
Greetings @davygillebert!
Can you please share more details about this failure? Does it output any logs?
@gustavo.tx it does output a log :
ERROR: core-image-minimal-1.0-r0 do_rootfs: Unable to install packages. Command ‘/home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/recipe-sysroot-native/usr/bin/opkg --volatile-cache -f /home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/opkg.conf -t /home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/temp/ipktemp/ -o /home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/rootfs --force_postinstall --prefer-arch-to-version install dosfstools e2fsprogs meta-aedin opkg packagegroup-core-boot packagegroup-core-ssh-openssh run-postinsts’ returned 255:
after which an entire list of all packages it tries to install is printed. Configured etc…
and it ends with:
*Collected errors:
- check_data_file_clashes: Package meta-aedin wants to install file /home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/rootfs/etc/hostname
But that file is already provided by package * base-files
un-postinsts.
ERROR: core-image-minimal-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/gillebert/develop/30012600/src/usbboot/build/tmp/work/colibri_imx8x-tdx-linux/core-image-minimal/1.0-r0/temp/log.do_rootfs.2148
ERROR: Task (/home/gillebert/develop/30012600/src/usbboot/build/…/layers/openembedded-core/meta/recipes-core/images/core-image-minimal.bb:do_rootfs) failed with exit code ‘1’*
When I do not add the precompiled binary
DESCRIPTION = “autorun” SECTION =
“aedin” LICENSE = “CLOSED”
FILESEXTRAPATHS_prepend :=
“${THISDIR}/src:” SRC_URI =
"file://autoBackup.service
file://autorun.sh
file://partition.sh
file://blink.sh
file://hostname
file://dspprog \ " BBFILE_PRIORITY_${PN} = “31”
INHIBIT_PACKAGE_STRIP = “1”
INHIBIT_SYSROOT_STRIP = “1”
tried these options INSANE_SKIP_${PN} += “ldflags”
FILES_${PN}-dev += “${bindir}/dspprog”
FILES_${PN} += “${bindir}/dspprog”
inherit systemd
do_configure(){ : }
do_compile() { : }
do_install() { install -d
${D}/${systemd_unitdir}/system/
install -m 0644 ${WORKDIR}/autoBackup.service
${D}/${systemd_unitdir}/system/autoBackup.service
install -d ${D}/${bindir}/
install -m 0755 ${WORKDIR}/autorun.sh
${D}/${bindir}/autorun.sh
install -m 0755 ${WORKDIR}/partition.sh
${D}/${bindir}/partition.sh
install -m 0755 ${WORKDIR}/blink.sh
${D}/${bindir}/blink.sh install -d
${D}/${sysconfdir}/
install -m 0755 ${WORKDIR}/hostname
${D}/${sysconfdir}/hostname
${D}/${sysconfdir}/hostname-opkg #
install -d ${D}/home/root/ install -m
0755 ${WORKDIR}/dspprog
${D}/${bindir}/dspprog }
so it only goes wrong when I try to add dspprog (the precompiled binary) this binary does work on the Toradex module when copied on it with a usb stick.
@davygillebert,
Can you share your meta layer so I can try your recipe on my side?
I see Yocto complained about a hostname
file that’s being installed. Does this error still happen when you don’t try to install your binary?
