I have an application that is comprised of C++ and C code modules. I have two bitbake builds, prod and dev. The dev image builds 100% of the time. The difference between prod and dev, dev has debug tools, prod build the main application and attempts to include it in the image. I cannot build the prod image. I am getting two errors that I cannot resolve. Note that my build script works on the target hardware as well as the development Ubnuntu platform.
I am using autotools, autogen.sh, configure.ac and makefile.am to build my application. The files are uploaded to this question.
mainapplication_0.0.bb (752 Bytes)
autogen.sh (142 Bytes)
build_project.sh (822 Bytes)
configure.ac (371 Bytes)
Makefile.am (316 Bytes)
myapplication.bb (160 Bytes)
myapplication.inc (1.4 KB)
myapplication-dev.bb (311 Bytes)
I have also attached my main image .inc and .bb files. I have installed can-utils and boost as required by my project.
The errors I am getting are as follows.
The following come from the same area of interest:
arm-poky-linux-gnueabi-gcc -mthumb -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 -fstack-protector-strong -O2 -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot -DPACKAGE_NAME=\"MAIN_Application\" -DPACKAGE_TARNAME=\"main_application\" -DPACKAGE_VERSION=\"0.0.1\" -DPACKAGE_STRING=\"MAIN_Application\ 0.0.1\" -DPACKAGE_BUGREPORT=\"michaelminer@smartrendmfg.com\" -DPACKAGE_URL=\"\" -DPACKAGE=\"main_application\" -DVERSION=\"0.0.1\" -I. -I../MAIN_Application -D_REENTRANT -D__X86_VERSION__ -DLINUX -I../MAIN_Application/include -I../MAIN_Application/include/comms/CAN -I../MAIN_Application/include/comms/PLC -I../MAIN_Application/include/comms/UART -I../MAIN_Application/include/CML_Integration -I../MAIN_Application/include/config_parsing -I../MAIN_Application/include/utilities -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/include -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EV -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EV/model/Generic -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EV/net -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EV/state -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EVVisitor -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/configuration -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/configuration/ev -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/msg -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/net -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/states -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/ApiV2g/ev -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/appHandshake -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/codec -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/iso1 -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/iso2 -I../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/v2g/xmldsig -I../MAIN_Application/vendor/carmedialab/SMG/trunk/TmCommon/sources/CmlCommon -I../MAIN_Application/vendor/carmedialab/SMG/trunk/TmCommon/sources/DccCommon -O2 -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0=/usr/src/debug/mainapplication/0.0-r0 -fdebug-prefix-map=/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0=/usr/src/debug/mainapplication/0.0-r0 -fdebug-prefix-map=/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot= -fdebug-prefix-map=/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot-native= -c -o src/utilities/dictionary.o ../MAIN_Application/src/utilities/dictionary.c
In file included from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/config/detail/select_stdlib_config.hpp:24,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/config.hpp:44,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/smart_ptr/bad_weak_ptr.hpp:20,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/smart_ptr/detail/shared_count.hpp:25,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/smart_ptr/shared_ptr.hpp:17,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/boost/shared_ptr.hpp:17,
from ../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/EV/state/IsoStatesMachine.h:6,
from ../MAIN_Application/include/CML_Integration/cml_integration.hpp:18,
from ../MAIN_Application/src/main.cpp:13:
../MAIN_Application/version:1:1: error: too many decimal points in number
1 | 0.0.0
version:1:1: error: expected unqualified-id before numeric constant
This is coming from /build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/c++/10.2.0
The next is
In file included from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/sys/socket.h:33,
from /home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/netinet/in.h:23,
from ../MAIN_Application/vendor/carmedialab/SMG/trunk/ISO15118_Stack/sources/common/net/v2gtp.h:34,
from ../MAIN_Application/src/CML_Integration/sources/EV/state/dc/SMG_EvStateImpl.cpp:7:
/home/michael/Documents/MAIN_Application/build-fb/tmp/work/cortexa7t2hf-neon-poky-linux-gnueabi/mainapplication/0.0-r0/recipe-sysroot/usr/include/bits/socket.h:260:5: error: 'socklen_t' does not name a type; did you mean 'locale_t'?
socklen_t is defined in unistd.h which is present in my recipe-sysroot folder under usr/include. Is there a clear issue with my build files? I have been searching for an answer for a few days now and I have come up empty handed. Hoping someone here can assist.
