The bitbake fetch progress bar filled with ‘#’ to 100 % but then I see ‘<=>’ slide back and forth in the progress lane until I get the fetch error failed with exit code 128; fatal: read error: Connection timed out.
I am able to git clone the repos as a separate task so I have access to the repos.
If you have the git repos in your download directory, you could try to manually update them before starting bitbake again.
cd .../downloads/git2/git.toradex.com.u-boot-toradex.git/
git remote update
You could try to do a cleanall on the failing recipes which will also remove fetched files for that recipe (which might be garbled and block a successful download)
Did you by chance run bitbake as root? (Which I think is nowadays not possible anyway).
That way there might be files which now cannot be changed and make the fetch fail.
Is there anything in the bitbake log pointing to the error?
Thanks Max for your quick response. Let me try a couple of things you suggested. I did not clone the repos into the download directory but I can. I tried cloning them to verify I had proper access to them through my corporate network. I ran bitbake clean on the failed recipes but I did not specify them as you did like virtual/bootloader. So let me try your suggestions and then if it still fails I will attach a log of the do_fetch failures.
Hi Max. I used your tip of cloning the 2 repos into the downloads/git2 directory using the corresponding local repo name syntax as you have shown above. Everything built properly after getting the virtual/kernal and virtual/bootloader source code downloaded into their proper place. I thank you for that help.
I noticed that is there are a number of new files for v2.7 / Morty in the …/deploy/images/colibri-imx6 directory like ‘Colibri-imx6_LXDE-Image.rootfs.sdcard.gz’ that are different than previously built v2.4 / dizzy. I previously built v2.4, loaded it on an SD card using 2 partitions, FAT32 and EXT3, booted it through running u-boot/sdboot. Can you please point me to v2.7 documentation that explains how to load and boot this version v2.7 from an SD card. Is there a reference explaining all of the files generated in the images directory tree? I know there is now a Secondary Program Loader step in this release as well. How is that executed in the boot process from an SD card?
