I’ve always been Linux oriented, but the fast boot time of VF61 with Windows has led me to take into consideration this Os.
Nowadays the best setup for Colibri Vf61 is :
- WEC2013 with lastest sdk\bsp
- VS2013 with the right app builder
Is it correct? ( I got this working )
Speaking about Qt, Toradex provides set up instructions for VS2008 and Qt 4.8.
Is this setup applicable on VS2013? It seems you provide Qt 4.8 Sdk while i think from Qt side 4.8.4 is not applicable directly to VS2013, you need to find the right patch.
The point is i am seeking a clean Qt solution on win ce with Vf61, no matter which Os or VS version i’ll use.
Thanks in advance.
Matteo.
